Old 06-28-2009, 12:29 AM
RoMi RoMi is offline
Default Pro Tools key shortcuts for REAPER
I have seen many questions about it on the DUC and REAPER forum, so here are basic Pro Tools key shortcuts for REAPER, focused mostly on Pro Tools "Commands Keyboard Focus Mode" one-key stroke commands.
http://stash.reaper.fm/v/3110/Robert...R.ReaperKeyMap
As a Pro Tools user, I wanted to create a key map that I used the most. It is a good start point for a transition from PT or for an easier use of both DAWs.
The PDF file with the key map can be found here: www.Robert-Millord-Music.com > Links.
The blue-highlighted keys in that PDF key map are similar to the Pro Tools ones. The rest is REAPER inherent.
The blank spaces contain the key shortcuts to be found in the original ReaperKeyboardShortcuts.pdf file.
Of course direct translation of shortcuts/macros is not always possible, but...
Enjoy,
Robert Millord
Intel quad Q6600, ASUS P5K DeLuxe WiFi, Radeon HD Gfx cards, 3 LCD monitors, Focusrite Saffire PRO 24 DSP, Win 7x64, REAPER 64bit, Wavelab.
Old 06-28-2009, 01:45 AM
RiF RiF is offline
Default Re: Pro Tools key shortcuts for REAPER
Thanx a lot! As I am switching back and forth between PT and Reaper, because I cannot decide which one I am finally using, I appreciate such a keymap.
Old 06-28-2009, 02:11 AM
AndyJCP AndyJCP is offline
That's absolutely fantastic, thanks!
I always pressed "R" and "T" in Reaper and wondered why it didn't zoom.
Andy
Old 06-28-2009, 01:52 PM
I'm glad you found it helpful
Robert Millord
Old 06-28-2009, 07:07 PM
I just corrected my file in the REAPER stash.
It is a ZIP that contains the KeyMap file, the PDF and the Excel source file.
http://stash.reaper.fm/v/3113/Robert...n%20REAPER.zip
Robert Millord
Old 05-26-2010, 02:52 PM
joeldadrummer joeldadrummer is offline
Hi. I'm totally new to Reaper, but a long time PT user. Could you explain in a bit more in detail how to set up reaper like PT? I've opened reaper and downloaded your file but I'm a bit lost as how to get it to use the same key commands as PT.
cheers,
Joel
www.joelfountain.com
Why can't I rewire Reaper into Pro Tools. benherron.rrr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-15-2011 03:39 PM
Pro Tools and Reaper compatibility nairobijones General Discussion 1 08-23-2010 08:22 AM
Pro Tools to Reaper... Need some help! DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 42 03-15-2010 08:24 AM
Reaper and Pro Tools 8? jebwick General Discussion 50 09-23-2009 07:20 PM
OT - PT / REAPER sound settings (and shortcuts) ChadB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-05-2009 07:51 AM
