Old 04-04-2006, 01:46 AM
mrbobb mrbobb is offline
Default Can\'t choose \"Link to Source Media\"
In the Import Session Data window, the option for "Link to Source Media (where possible)" is grayed out. I'm not trying to copy from an OMF. I need to pull in 90 min. worth of audio files (somewhere around 5 gigs worth) from another Pro tools session and really don't want to deal with double files and all that. Both sessions are 16 bit, 48 k. I tried a few other PT sessions, and wasn't able to "Link" any of those either, only "copy" showed up. Any ideas? Thanks.
M
Producer/Songwriter/Mixer
www.matchstickmusic.com
Old 04-04-2006, 04:30 AM
minister's Avatar
minister minister is offline
Default Re: Can\'t choose \"Link to Source Media\"
are you sure bit depth, sample rate and file type are identical in each session?
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 04-04-2006, 04:31 AM
Soundworks UK Soundworks UK is offline
I've had this recently too. v.7.1 Same file format, bit rate, sample rate, valid playback and/or record drive etc. only 'copy from source media available....strange...
Simon Jones
Freelance sound creative. Bristol / Cardiff, UK
Re-recording mixer specialising in TV drama.
Mac Studio M2 Ultra 64gbRAM Focusrite Red16 line, Pro Tools Ultimate 2023.6
Old 04-04-2006, 09:39 AM
Yes, I'm sure, everything that come my way gets transfered first. 16 bit, 48 k, AIFF. I pulled up my session set up window while I was importing just to double check. It was late last night and I forgot to mention I'm on 7.1 LE with DV toolkit 2. I can remember this option working under DV Toolkit 1, Could that be the problem, or are any HD guys experiencing the same thing? thanks
M
Old 04-04-2006, 02:51 PM
minister's Avatar
only thing i can think of if it is DV TOOLKIT 2, is if you are not in the admin account on a MAC.
otherwise, i got nada...
Tom Hambleton CAS
IMDb
-Starcrash
Old 04-04-2006, 03:02 PM
jimlongo's Avatar
jimlongo jimlongo is offline
I had this last week. It seems that now the Import Session Data function recognizes the PTs Pref for "Always Copy files on Import" and if that is checked then you cannot Link to other sessions files.
noise | jimlongo
Old 04-04-2006, 03:13 PM
Great, thanks for the answer Jim. That was the trick.
M
Old 07-25-2012, 01:57 PM
riggi riggi is offline
Default Re: Can't choose "Link to Source Media"
When you are importing a session data AAF file, MAKE SURE the bit depth matches your Pro Tools Session.
I had two different Sony cameras footage in Media Composer. One while importing had errors in it (a bug from Media Composer) turns out. I edited a 20 minute sequence and it went fine. When I created an AAF file to 'link to source media' in pro tools, that choice was greyed out.
I did notice that in the Source Properties in Pro Tools during an Import Session Data workflow, the Audio Bit Depth was 16,24
All video's audio that I've worked with so far has always been 16bit 48Khz. So to see 24 in the bit depth as well was a bit odd...
So I returned to Avid Media Composer and when I did an export I selected covert audio to 16bit and 48Khz (2 separate check boxes in the export dialog)
That solved my problem. So it maybe your problem too.
HTML code is On
AAF Link to Source Media not working PandaHouse macOS 2 03-02-2013 07:24 AM
Source Connect and Satellite Link Snowmelt Post - Surround - Video 3 11-24-2011 11:47 AM
OMF Protools 7.3 Cannot link to source media ErockZ Post - Surround - Video 25 05-01-2007 03:12 AM
Consolidate from Source Media 7.2 bug? ryan de topanga Pro Tools TDM Systems (Mac) 1 09-30-2006 03:48 PM
Link to source media greyed out in digitrans? Frank Kruse Post - Surround - Video 1 09-12-2005 08:48 AM
