\"DSP Unavailable\" (oh but it is....)
I'm running a MixPlus system (with an additional DSP farm) on OS 10.3.4 (PT 6.4), G4 Quicksilver.
I keep having situations where plugins get dropped when I open sessions that are close to my DSP useage limit. The plugs are all sitting nicely on chips when I close the sessions, but when I re-open the session, PT doesn't remember how it allocated the DSP last time, does it less efficiently, and then thinks it doesn't have room for all the plugs (usually a verb, EchoFarm or something on an aux track at the right of my mixer). I then have to start pulling plugs out and re-instating stuff to force PT to rejuggle the load until it all to fits in again. Question: is there a way to get PT to remember how it allocats the DSP, and/or is there an easier way to force a DSP juggle? |
Re: \"DSP Unavailable\" (oh but it is....)
The farther to the left (in the MIX window) a track is, the higher a priority it has when the session is loaded and DSP is allocated.
Try putting delay/reverb based plugins on the left of the mix window. Same with heavy Waves plugs, but it might take a little tweaking and experimenting to understand in what order the first and the latter should go, as Waves uses a shell system.
Mark Haliday France, Rochefort 17300 Mixing & Mastering, Writer, Teacher Pro Tools Ultimate & Carbon M2 Max Studio |
Hi.
you wrote that you are using an additional DSP-Farm in your Mix+. I wanted to buy one too for my Mix+ but was told be some pro-seller in germany that i would not be useful since most of the newer plugs-do not run on this farm. i am running a PT 5.1.1 on OS 9.1 with a PowerPC 9600/300 and the plugs i am using are : FOCUSRITE, TC Megareverb and the WAVES TDM/Gold-Bundle (i will use it as soon as i managed to update it after my upgrade from OS8 to OS9 and PT 4.3 to 5.1.1). Does it make sense to add additional SP-Farms or will it be useless? Thanks for your answers.
-Mario Dahmen / enginEAR |
The DSP farm cards are GREAT values and can run lexiverb, 1176, la-2a, focusrite, amp farm, just about ANYTHING you can throw at em. get one, no, get 2 or 3 or 4. I'd take 2 dsp farms over a mix farm anyday.
BTW -- thanks to Chief Technician and frenchman for the the tips on DSP allocation |
ASIO4ALL - Unavailable?? | Wyn | Windows | 2 | 09-05-2011 05:41 AM |
Export as OMF/AAF unavailable? | acrisisofsound | Post - Surround - Video | 13 | 12-21-2010 02:24 AM |
Unavailable fades | Stickist | Pro Tools M-Powered (Win) | 0 | 04-04-2006 05:05 PM |
Outputs unavailable | stevegalante | Pro Tools TDM Systems (Mac) | 0 | 09-09-2005 09:54 AM |
Last voice unavailable | kcreature | Pro Tools TDM Systems (Mac) | 0 | 04-25-2000 01:58 PM |
