Old 02-17-2012, 11:21 PM
Default -9094 errors in PT 10
Running PT 10.1 with VE Pro (hosting VSL and MachFive3 in a 64-bit server process).
I get a lot of -9094 errors when tracking VIs ("Audio processing could not complete due to conflicts with other CPU tasks or a potential clocking issue...").
Playback engine is at 128 samples (any less is unplayable), 6 processors, 99% usage limit, 256 voices, 44.1KHz. Sibelius is also ReWired in but this doesn't appear to make much difference.
Running HDX, OS X 10.7.2, MacPro5,1 (3.33GHz 6-Core), 24GB RAM.
Any ideas? Surely this is not that complicated in 2012.
https://lukehoward.com/
Old 02-18-2012, 11:43 AM
Default Re: -9094 errors in PT 10
Drop the host processing units in Pro Tools to 3 to balance online and offline duties with Pro Tools and VEP.
Aaron Mulqueen - 001 HD Native
Old 02-18-2012, 03:40 PM
Is this the number of processors in the playback engine? Because it's at 6 (of 12) already. Or is this another setting?
Old 02-19-2012, 12:03 AM
Hmmm... how many processors set in VEP? Is everything balanced, perhaps you need to look a bit deeper, to drivers and utilities.
Old 02-19-2012, 04:29 PM
VEP was set to 2 threads. I'll try some more and see what happens. Thanks!
Old 12-15-2012, 05:46 PM
LarsSlate LarsSlate is offline
Protools bug.
GOing from LE8 to HD NAtive 10 has caused all kinds of issues and I am 100% hardware compliant with Avid.
still have -9094 errors scubadrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-18-2009 01:03 PM
Help w/(9129),(9094) errors joewilly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-07-2006 08:53 PM
Cured my -9094 buffer errors! stevegrisham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-15-2004 08:16 PM
9094 errors.. Please Help. Thanks in advance. Smelt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 08-11-2003 12:57 AM
9129 and 9094 errors KdC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-30-2000 10:34 AM
