-9094 errors in PT 10
Running PT 10.1 with VE Pro (hosting VSL and MachFive3 in a 64-bit server process).
I get a lot of -9094 errors when tracking VIs ("Audio processing could not complete due to conflicts with other CPU tasks or a potential clocking issue..."). Playback engine is at 128 samples (any less is unplayable), 6 processors, 99% usage limit, 256 voices, 44.1KHz. Sibelius is also ReWired in but this doesn't appear to make much difference. Running HDX, OS X 10.7.2, MacPro5,1 (3.33GHz 6-Core), 24GB RAM. Any ideas? Surely this is not that complicated in 2012.
https://lukehoward.com/ |
Re: -9094 errors in PT 10
Drop the host processing units in Pro Tools to 3 to balance online and offline duties with Pro Tools and VEP.
Aaron Mulqueen - 001 HD Native |
Is this the number of processors in the playback engine? Because it's at 6 (of 12) already. Or is this another setting?
Hmmm... how many processors set in VEP? Is everything balanced, perhaps you need to look a bit deeper, to drivers and utilities.
VEP was set to 2 threads. I'll try some more and see what happens. Thanks!
Protools bug.
GOing from LE8 to HD NAtive 10 has caused all kinds of issues and I am 100% hardware compliant with Avid. |
still have -9094 errors | scubadrum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-18-2009 01:03 PM |
Help w/(9129),(9094) errors | joewilly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-07-2006 08:53 PM |
Cured my -9094 buffer errors! | stevegrisham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-15-2004 08:16 PM |
9094 errors.. Please Help. Thanks in advance. | Smelt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 08-11-2003 12:57 AM |
9129 and 9094 errors | KdC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-30-2000 10:34 AM |
