  #21
Old 04-23-2017, 01:29 PM
zavid zavid is offline
Default Re: HD vs Native differences in mixdown-bounce
Originally Posted by JFreak View Post
HD (TDM) sounds different, because that's a whole different mixer. MIX is somewhat similar to HD because they both share the 24-bit fixed limitation; however, HD has double precision compared to MIX so there's a big difference.
Sadly, something like 15 years ago, the "lowly" LE systems sounded better than MIX because of 32-float mixer. DigiDesign/Avid obviously didn't want to talk much of that.
But now that HDX and HDN share the same architecture, there is no difference
if you have same material and same plugins.
thanks for post ,
If I understood correctly,
and if it's true that :
and then no difference ,
no "dynamic" data reduction/compression,
The only limit is the Cpu power ,
and dsp cards are required only for large sessions with large number of tracks and plug ins ,
That a Daw with i7 processor cannot "manage" ?
  #22
Old 04-23-2017, 10:10 PM
JFreak's Avatar
JFreak JFreak is offline
Yes. The maximum i/o for HDN is 64 and if you need one more you need to have HDX.
And yes, "CPU+DSP>CPU", always. With that said, current computers have become so fast they run circles around my old HD3 TDM system. With this rather old late-2013 MBP, I can easily create bigger mixes than the HD3 ever could.
Janne
  #23
Old 04-24-2017, 02:49 AM
thanks for post
Which is why many guys that normally work with no large sessions,
sold cards , and got Native,
also for work on a laptop "everywhere"....
  #24
Old 04-24-2017, 03:42 AM
JFreak's Avatar
well the laptop and working everywhere is kind of limited, because once you start to use plugins, the laptop fan makes the experience... "limited"
if you can afford it, you really should buy an iTrashcan which is dead silent.
Janne
Native vs HD - the differences calmposer Pro Tools 10 9 11-13-2015 07:40 AM
Offline bounce vs. Realtime bounce significant differences Mano Pro Tools 11 13 05-29-2014 05:58 PM
Best Way to Bounce/Create Mixdown shameusf Pro Tools 11 2 11-10-2013 06:08 PM
Bounce (mixdown) stops due to cpu overload Eli V/d Vondel Pro Tools M-Powered (Win) 1 01-29-2007 06:37 AM
5.1 Mixdown to Stereo Bounce stealth_162 Post - Surround - Video 11 02-04-2006 02:08 PM
