Closed Thread
  #131
Old 04-24-2017, 05:49 AM
Drew Mazurek's Avatar
Default Re: Where is 12.8?
Originally Posted by nige108 View Post
Yep, no more money from me. I'm fed up with making blind payments. How many other companies take money from there customers and don't tell them what they are getting for it?
What are you getting? Their continued existence.
www.drewmazurek.com
  #132
JFreak's Avatar
JFreak JFreak is offline
Well we all have our own opinions regarding priority of new version wishes, don't we? I myself agree with plugin chains and track presets feature requests. Those would be great, if properly implemented.
But I actually disagree with the polarity switch thing unless there's a polarity switch for every send as well. The problem is, if there is such a "plugin" in every output of a mixer, it needs some processing time and how it would be implemented with HDX beats me. Not to mention, it should be easily controlled with control surfaces such as C|24 which is a lot older than this feature request. I'm fine with inserting a plugin for it.
And the bus soloing... I don't get it why people are so desperately crying for it. PT mixer is as close as it gets to analog console, and using analog console I have never needed this. If I wanted to hear what the reverb is getting, I simply turn the mix knob to zero. Multiple sessions... Well... I don't mind if it's implemented but I don't need it. Import Session Data is good enough for me. Undoing deleted tracks? That's something Avid could perhaps implement, but obviously it wouldn't work if you had already deleted the files.
Point being, Avid isn't in the business of implementing everything their customers ask for. They are in the business of pleasing their most lucrative market (post) and they also need to be a gatekeeper of denying feature requests that mess with their golden goose.
Janne
  #133
Old 04-24-2017, 05:58 AM
nige108's Avatar
nige108 nige108 is offline
You have to laugh otherwise you'd cry
  #134
Old 04-24-2017, 09:55 AM
amagras amagras is offline
This delay is starting to smell like ilok licence replacement...
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
  #135
Old 04-24-2017, 10:56 AM
DarkandKurious DarkandKurious is offline
I think you're making a very valid point. Most people's feature requests seem to be about their specific situation rather than the broader picture, even from a technical viewpoint. Multiple sessions open at once? How would all the routing work when you have a different I/O setup for hardware inserts on different channels? It is ITB people who want such things, yet PT doesn't even handle one heavy mix session with VI's well. When the foundations of the software is shaky, things like this are asking for even more trouble. The soloing has so much flexibility that I have always found a way to hear anything I wanted to solo. Making sure that the delay compensation doesn't go haywire because some bus is orphaned from an output, making sure that we can trust what we see on the screen, implementing a better graphics engine so that there are less errors or crashes because PT can't redraw the waveforms quickly enough, fixing the underlying stability, reducing the problems with multithreading, those things are necessary for everyone, in every industry, every day. I personally think people should stop requesting new features and continue to ask for stability, and nothing but stability. The crashes because of conflicts in memory management and CPU management need to go.
Mac Studio M1 Ultra 64GB
macOS 13.2.1
Pro Tools 2023.3
Antelope Audio Discrete 8 SC
  #136
Old 04-24-2017, 11:36 AM
electrodaddy electrodaddy is offline
Apparently there have been six major releases in the past year. I can only count two. What did I miss?!
https://twitter.com/AvidProTools/sta...33753486331904
  #137
Old 04-24-2017, 11:51 AM
Southsidemusic's Avatar
We have had quite a few updates to PT and I think they are also counting freeze, commit, Cloud Collaboration and new HD Driver but IMNSHO Iwould NOT call the dot updates "major releases" as they were needed to even get PT to start so I am with you there. Maybe they (Avid) count MC aswell
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #138
Old 04-24-2017, 12:00 PM
Cloud, freeze and commit we're over a year ago. Sand bug fixes certainly don't count as a major release. Definitely some fibs going on there!
  #139
Old 04-24-2017, 12:23 PM
clausiii's Avatar
clausiii clausiii is offline
I think people who want multiple open sessions want it the way how Nuendo handles this. One session is active, others are kinda disabled but open. You can copy/paste things and so on or quickly enable another session (and the first session is then disabled). It's quite useful in certain circumstances.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
  #140
Old 04-24-2017, 12:44 PM
deanrichard deanrichard is offline
Exactly. This is how most DAWs that support multiple sessions work. Only one is active at a given time. There is added convenience because you can quickly switch between sessions, and also because you can easily cut from one session to paste to another. But again, only one is active at any given moment. And DAWs that support Sub-projects are similar in that only one project is open and available at any given moment.
Closed Thread
