12.7 Sync drift issue. PC
I have 3 PT 12.7 systems, 2 are HDX with BM and one with Focusrite Scarlett Solo and BM Studio 4K. All on PC based Z420 systems. All 3 drift out of sync after playing for half an hour. If I play with a looped sequence IE, 12 hours, the sync goes out by 3-4 seconds. Two are synced by word clock and the other is free running. Video is linked via AAF to DNXHD media on Isis 5000. Anyone else had this issue?
3 X Z440 W10 32GB RAM, PT 2022.10/2022.4 HDX, 1 X Omni, 3 x X-Mon/S6, 1 X Scarlett Solo, 4 X Blackmagic 4K Extreme, NEXIS E4, Isis 5000, S6 X 3. Synced with Nanosync Word clock. Last edited by ShadeTek; 02-21-2017 at 08:57 AM. |
Re: 12.7 Sync drift issue. PC
Here is an image of the overlay BITC, PT TC and External monitor BITC drift.
3 X Z440 W10 32GB RAM, PT 2022.10/2022.4 HDX, 1 X Omni, 3 x X-Mon/S6, 1 X Scarlett Solo, 4 X Blackmagic 4K Extreme, NEXIS E4, Isis 5000, S6 X 3. Synced with Nanosync Word clock. |
I didn't think it was possible to sync machines via wordclock. You need timecode or MTC, AFAIK
Word clock will dictate speed provided it's working properly. Timecode determines position.
Something is broken or not set up properly because this is a hardware issue.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Is this the only project with sync issues ?
Same amount of drift on all three rigs ? Frame-rates ? Pull up/downs ?
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
I been having issues with video sync on 12.7HD HDX Mac 10.9 lately
If I start 12.6.1 it's not doing it. Perhaps there is something going on. |
I am having major sync drift issues as well PT 12.7.1 OS Sierra (10.12.3). I am playing back a mix that I did last week in PT12.4 (10.10.5), sync was perfect for the mix. Now, same session is drifting (audio becomes late) VERY quickly, noticeable after 15-20 secs of playback in 12.7.1. Everything indicates my system is properly clocked and locked to my Sync I/O. The sync of the QT window within Pro Tools drifts out. Also noticed a HUGE increase in video sync offset with PT 12.7 versus PT 12.4? My offset for PT 12.4 was 12qf, now my offset in 12.7 is set to 34qf. And yes, no matter where I'm at in the session, I'm in sync when I hit play, then drift occurs. Going back to 12.4 until this is addressed. Avid, any ideas on my situation? Thanks.
Hey there, don't know if it helps but I remember a friend recommending to go with BM drivers 10.4.1, old and from 2015 I think.
Solved similar issues we were having on the stage we were in. Hope this helps? :-\ |
Video use Frames
Audio use samples You need a Video GEN sending video ref to your Avid SYNC and then from the Video ref out of your AVID SYNC connected to your BM card (video ref in) to be perfectly locked. You can use something like http://www.rosendahl-studiotechnik.de/nanosyncs.html that send VIDEO SYNC to your AVID SYNC. At your Session setup you then choose the AVID SYNC to be the clock source, then in the SYNC Setup configure it to your need. All 3 lights should be ON. By the way we use 10 rooms with this setup, all the rooms use the BM driver 10.4.1. We have a stable offset that we checked with Syncheck (all our TV's are the same that makes even flawless the test). BE careful each TV manufacture and settings of the TV make the video offset change.
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro |
Sync (sound drift) issues | vzankovsky | Tips & Tricks | 5 | 04-25-2014 09:17 AM |
LTC / MTC Drift sync issues | Aquarius | MIDI | 0 | 02-03-2010 04:31 PM |
FCP Drift Issue | EarHole | Post - Surround - Video | 6 | 04-30-2009 06:45 PM |
Sync drift across reels | Pete Gates | Post - Surround - Video | 1 | 06-19-2007 09:07 AM |
Sync drift on FCP 4 23.976fps QT in PT 5.1.3 | twarren | Pro Tools TDM Systems (Mac) | 5 | 01-30-2004 07:36 AM |
