Could not complete your request because integer error occurred (divide by zero)
Hello,
I am new to pro tools. I have recently downloaded the trial version of pro tools 10. It worked fine until I tried to open some .AAF sessions. When ir starts opening the session I get the following error message: "Could not complete your request because integer error occurred (divide by zero)" I am on Windows 7 64bit, 12 GB of RAM i7 8core. Can someone help? kind regards joni |
Re: Could not complete your request because integer error occurred (divide by zero)
Divide by zero . . . unforgivable! Fire the programmer.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Is this an unknown issue? I wonder if there is a workaround..
Thanks Joni |
I've seen some problems with AAF, but not a divide by zero issue. That's one that would stand out. Maybe try exporting the AAF again and/or try OMF. What's your AAF authoring software?
Hi ChuckS, thanks for your reply.
The AAF was exported from NUENDO. I will ask them to send me another AAF. I have exported some OMF's from Sonar and they open fine in PT. What does this "Divide by zero" means by the way? |
It's just a condition that every programmer should be aware of and test for - programming 101.
tried to google it but it only refers to an error common back in Pro Tools 8 after CS3 or something.
Not serious. I am just testing PT to add it to the studio (which is based on Sonar and will remain the main software if it depends on me). Thanks for you help joni |
Could not complete your request because Access violation occurred | ToddnTodd | Windows | 7 | 02-21-2013 09:38 PM |
Pro Tools could not complete your request because access violation occurred | naustin | Windows | 1 | 04-07-2012 02:32 PM |
Could not complete your request: Access violation occurred | StLegion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-20-2007 07:41 PM |
Could not complete your request acces violation occurred | tkd__ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-26-2007 10:40 PM |
integer error occurred-digi001- HELP!!!!! | hitwriter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-30-2006 02:01 PM |
