#21
Re: Purpose of Outputs on HD IO 16x16 Analog
The "Pro Tools IN" connector on C24 is exactly what it says, it takes all analog inputs in one DB25 connector. Bear in mind (this is what is in the manual) that Right channel isn't channel number two but instead it is number three. Channel number two would be Center channel. So if you are only using it for stereo, you need to connect channels 1 and 3 on the C24 end and you probably have stereo output using channels 1 and 2 on the HD interface.
If you don't buy that ready-made cable kit, here's what I suggest (and if you don't do your cables yourself, the mentioned proaudiola.com is very helpful):
Now you have a monitor controller wired properly, the master volume on your C24 controls your monitor volume.
#22
Thank you very much!! I believe I have all the cabling necessary to make this work the way you described. I was wondering how to get around the L=1, R=3 dilemma without buying custom made snakes. I was looking around for the Avid snake set and apparently they're no longer available and I don't have a lot of cash, so the workaround you described is basically my only option. Sent from my iPad using Tapatalk |
#23
Thanks, JFreak, took your advice and it worked like a charm. The real problem, after getting straight on the outs from HD IO to C|24, was that I was using the wrong set of outs from the IO. 9-16 instead of 1-8... STUPID on my part.
#24
I left you a voicemail on your home phone yesterday. I have been in Italy and just got back.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
#25
Great :)
#26
As an epilogue, and a huge thanks to all who replied, the basis of my current understanding (which is actually pretty good now), is that I've realized that there are few similarities between live sound equipment and studio purposes equipment when considering IO. This comes mainly through the realization that most integrated mixers do not allow the configuration of IO routing and Pro Tools relies on this flexibility. Of course, I now get the fact that without routing analog audio back to the C|24 from the HD IO, there's no way I would ever get audio to monitor or cue outputs. Once again, thanks!
#27
#28
#29
+1
Glad u got it sorted out in your head. I think we can all appreciate the frustration of not having all the info we need. I just wanted to make sure you don't hesitate to ask your questions on here. Obviously try to find some answers in other threads before posting a new one but with that said, there are a lot of cool people on here willing to help. Have fun playing with all your new toys!!
Pro Tools Carbon | HD Native 2021.12 | HD I/O 8x8x8 | UA 4-710D | Avalon VT737 | Waves Mercury | Komplete 13 Ultimate Collector's | Kontrol S61 | Maschine Studio | Eleven Rack | Pro Tools Control w/ 9.7" iPad Pro | Pro Tools Dock | S1 | MacPro 7,1: 16-core 96GB RAM W5700X GPU OS 11 1TB SSD +OWC 1m2 2TB SSD (samples) +Sonnet M.2 4x4 4x2TB Samsung Evo Plus SSDs in RAID 0 (sessions) |
FS: HD 16x16 I/O Analog- EC | docric | Buy & Sell | 1 | 08-11-2016 01:10 PM |
HD I/O 16x16 Analog +1-2 | MarkH | Pro Tools HDX & HD Native Systems (Mac) | 2 | 01-20-2016 08:48 AM |
HD I/O 16X16 Analog W/Logic X? | triton92 | Pro Tools HDX & HD Native Systems (Mac) | 28 | 03-11-2015 10:20 PM |
HD I/O 16x16 Analog Revision A and B | SoundReplay | Pro Tools HDX & HD Native Systems (Mac) | 0 | 07-04-2014 05:52 AM |
HD I/O 16x16 Analog | maxx.monopoli | macOS | 5 | 02-17-2012 10:19 AM |
