Old 05-03-2018, 06:17 AM
Toon Develtere Toon Develtere is offline
Default Top Menu (file, edit, view,...) appears cut off on screen
My menu at the top appears cut off (see attached image). All the functions work normally, it is just annoying. It used to not be this way but suddenly Pro Tools started showing it like this and I have no idea how to get it back to normal.
When I start up Pro Tools, it appears normal but the moment everything is done loading and the dashboard appears it changes. I think it has something to do with my external monitor I use (it's an older TV with HDMI connectivity). But even when I'm not using an external monitor I still get the problem.
I also think everything in general is smaller than it should be (see attached image 2).
Does anyone know how to put it back to normal?
Greeting Toon Develtere
Old 05-03-2018, 06:19 AM
amagras amagras is offline
Default Re: Top Menu (file, edit, view,...) appears cut off on screen
I think you just have to maximize the session window (not the whole Pro Tools, the floating Windows inside) and it will adapt to the space available without interfering with the tool bar
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 05-03-2018, 01:28 PM
Its your DPI scaling setting.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 01-02-2021, 03:00 PM
royboy45 royboy45 is offline
Having same issue. Anyone help?
Old 01-02-2021, 04:04 PM
Look up guitardom probably nailed it. If not, its tough to give advice with so little information. How big is the screen and what resolution are you trying to use?
Old 01-03-2021, 04:48 AM
crizdee's Avatar
crizdee crizdee is offline
Hi
Tried resetting your screen resolution or trying a different resolution?
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-03-2021, 05:59 AM
JoelG's Avatar
JoelG JoelG is offline
Pretty sure it is the scaling as mentioned.
Not at my PC currently, so steps might be a bit off..
Right click on the Pro Tools shortcut, Properties
Compatibility tab, Change settings for all users
Change high DPI settings
Check the Override checkbox and set it to System.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 01-04-2021, 07:44 AM
ejinbc ejinbc is offline
OP
I get exactly what you are seeing when I adjust scaling in the Display Settings. PT likes to run at 100%, my eyes like to run at 125% (on a 4K 65" monitor). My solution is to always start PT at 100% scaling, once PT is up I adjust scaling to 125%. After I close PT I reset the scaling to 100%. If I forget to reset the scaling, the next time I start PT the menus are messed up as you show - Hey Avid, ever gonna fix this ?
YMMV
ejinbc
Old 04-08-2022, 02:38 PM
Kristan77 Kristan77 is offline
Thanx so much for this, JoelG! Was struggling with this on my newly built PC. This solved my problem.
Last edited by Kristan77; 04-08-2022 at 02:41 PM. Reason: Wanted to specifically thank JoelG so the proper thread is referenced.
Plug in appears in Audiosuite menu but not in my inserts angie450 Pro Tools 10 10 01-19-2019 02:12 PM
[Questions] Solo all routed channels in one click, mixer view follows edit view Eytan3000 Pro Tools | Intro Discussion 1 10-02-2017 02:30 PM
Following power outage the 11R screen no longer appears World Spirit Eleven Rack 3 01-20-2012 03:39 PM
Quick key for changing edit view to volume view in track? postman56 Pro Tools TDM Systems (Mac) 4 11-30-2007 10:56 AM
Control 24/Edit screen view select Brimmy ICON & C|24 1 11-05-2001 08:57 AM
