Can't assign LCR track to 5.1 bus
Mono tracks are routed 5.1 buses - check.
Stereo tracks are routed to 5.1 buses - check. If I create a LCR track and try to route it to any of the same 5.1 buses, in the track output drop-down there are no available buses. I'm obviously missing something important, but what?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM Over 30yrs experience in pro-audio - mostly for picture. |
Re: Can't assign LCR track to 5.1 bus
You need Spanner for universal panning in PT. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
So you can't do with LCR tracks what you can do with stereo tracks? Right?
But if you don't need the panning you can definitely route an LCR track to an 5.1 bus, if that was your question. frank.
If you need more flexibility you can get Spanner.
http://www.thecargocult.nz/spanner.shtml I don't work for them, by they way. The only drawback with it is that your sends must match your output, so if you use Spanner to turn a stereo into a 5.1 then your send has to be either 5.1 or mono. Without spanner a stereo track can have a 5.1 output and a stereo send. Also you have to get used to your pan info being plug in automation, not pan automation. Changes your workflow, but add many up-mix and down mix options. Plus has cool iPad app. |
[QUOTE=Frank Kruse;2230490]But if you don't need the panning you can definitely route an LCR track to an 5.1 bus, if that was your question./QUOTE]
That was what I was trying to do. As far as I can tell, you can route a stereo track to a 5.1 bus without a stereo sub path. But to route a LCR track to a 5.1 bus you need a LCR sub path. Is that right? (It seems a little counter intuitive to say the least.)
[QUOTE=idris;2230503]
If you want to hard-route stereo to L/R of a 5.1 without any panning you still need sub-paths. This is because PT only knows mono to whatever-panners. So on a mono track it gives you a mono to whatever panner. And on a stereo track it gives you a 'mono-panner per leg to whatever'-panner so essentially a dual-mono panner on a stereo track. For an LCR or any other multi-channel panner that would mean 3 or 4 or 5 panners per leg per track which would look and work completely silly with the panner concept that PT follows. So I guess they decided to stop at stereo. This is where Spanner comes into play. It gives you all panners for all 3,4,5,6 or 7 legs of a track in one interface. And you don't have to think about those crazy 7 (I think) parameters that PT needs to define a position.
Thanks Frank. Makes sense ... once you've stopped trying to figure out what you need to enable.
What is the source material that is in lcr that you want to pan in 5.1?
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
For perspective:
The surround mixer built into PT is something like 15 years old now, so you have to consider the context. Nobody mixed films in PT back then and almost every sound recording ever made was mono or stereo. So yeah, they could have had a little more foresight and definitely missed an opportunity, but for the time it was OK. |
Create and Assign New Track from Track | ZEROPRO | Windows | 2 | 12-05-2011 09:15 PM |
Can't assign audio to new track for mixdown | LSJ | Pro Tools TDM Systems (Mac) | 1 | 02-09-2011 06:29 PM |
cant figure out how to assign the optical in to a track? | greglarson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-06-2010 11:00 AM |
Audition track assign in 7.1cs4 | CD Productions | Pro Tools TDM Systems (Mac) | 4 | 03-22-2006 04:44 PM |
assign one voice per track | mario | Pro Tools TDM Systems (Mac) | 3 | 05-08-2000 12:31 AM |
