Old 06-13-2012, 03:42 PM
MixerGuy MixerGuy is offline
Question HDX-2 on (slightly revised) 12-core 2 x 2.4GHz 6-core Intel? / RTAS in PT10HD
Hi all
Well the new Mac Pros did not arrive as expected... and Tim Cook says "sometime in 2013"
I may pull the trigger on a HDX-2 on a (slightly revised, current) 12-core 2 x 2.4GHz 6-core Intel as a stop gap measure......
Anyone know if this (slightly updated) machine is "approved" for HDX?
and - confirming that RTAS plugs do work in PT10HD - ??
I'm leaning towards the 12 core as many plugins I use (Altiverb, etc) do NOT run in AAX, and TDM won't work, of course..... so the extra cores will be a place for RTAS plugs.
Will ProTools HDX take full advantage of all those 12 cores?
Would 12 GB ram be plenty for big mixes with 150+ audio tracks?
(with the audio for the PT session being around 4 GB max)
Final bonus round question
is the RAM in this machine registered.... or unbuffered?
(tough question, i know)I am told you can't mix and match types in one machine
Thanks
Old 06-13-2012, 03:49 PM
Emcha_audio's Avatar
Default Re: HDX-2 on (slightly revised) 12-core 2 x 2.4GHz 6-core Intel? / RTAS in PT10HD
The rtas will run as native version on pt 10 HD.
It's basically the same configuration of macs as it was for the past 3 years, so yes it will work. Same processors just slightly faster, and all the other parts are the same as for the past 3 years.
As for the ram (look under tech specs), they are ECC so they should be registered and buffered, if I'm wrong I hope someone will correct me.
Manny.
#BOYCOTTTUSPRODUCTS
just not Pro tools and compatible plugins...
Old 06-13-2012, 06:32 PM
francois francois is offline
Yes as Emcha mentioned all my TDM sessions opened with RTSA plugins except the few TDM only (eventide..)
As for the memory check OWC they have a good chart the Mac pro memory
PT 2018.4 -HDX1- OSX 10.14.5-MacPro 12 core 3.46
64 Gig ram- D-command 24-Trinnov Dmon
Old 06-13-2012, 11:10 PM
thanks for the info...
so...
Old 06-14-2012, 12:34 AM
so...
As always it's better to leave on full core (2 threads) for the os.
The 12 gig should be plenty for disk caching and vi use + plugs since the plugs will be limited to the 4 gigs that pro tools will see. Same for the vi's unless you run them rewired.
Manny.
#BOYCOTTTUSPRODUCTS
Old 06-17-2012, 04:56 PM
Default
Don't use any VIs.
Thanks tho.
So 6 cores for PT and 6 for OS would be good ?
Old 06-17-2012, 05:48 PM
Don't use any VIs.
Thanks tho.
More like 10 for PT and 2 for OS
Old 06-17-2012, 05:54 PM
What albee said
Manny.
#BOYCOTTTUSPRODUCTS
Old 06-17-2012, 09:33 PM
CentralCali CentralCali is offline
But the HDX has nothing to do with the 12 cores.... AAX Native will use them, AAX DSP and audio will use the power on the HDX cards. Or am I not understanding what you said....
Old 06-18-2012, 12:17 AM
read back the first posts, where he states that he will be using rtas too.
Manny.
#BOYCOTTTUSPRODUCTS
Motherboard Recommendations for Intel Core i7-2600K Sandy Bridge 3.4GHz xstortionist Pro Tools 10 0 04-19-2013 06:39 AM
Intel Core i7 2.0GHz Quad-Core Processor or Intel Core i7 2.7GHz Dual-Core Processor? okodub Pro Tools 9 3 09-23-2011 07:33 AM
6-core (3.33GHz) or 2 quad-core (2.4GHz) Westmere Detlef Brockmann macOS 4 02-18-2011 07:08 PM
6-core (3.33GHz) or 2 quad-core (2.4GHz) Westmere Detlef Brockmann Pro Tools TDM Systems (Mac) 7 02-18-2011 04:57 AM
2010 mac pro 2.4Ghz 8 core vs 3.33Ghz 6 core edadema Pro Tools TDM Systems (Mac) 32 09-07-2010 07:36 AM
