Old 10-20-2010, 07:07 AM
AnthonyW AnthonyW is offline
Default I/O connections on a 96I/O interface
Hi
I just got a Tascam M-520 mixer, it has all RCA connections for tape ins, and outs. Can I use 1/4" ring/sleeve connectors for I/O's on the 96I/O instead of ring/tip/sleeve? due to the RCA connectors to the mixer. Also does anyone know the max. length you can use for unbalanced cables before it effects signal loss ?, will be using quality cable.
Thanks
Old 11-15-2010, 08:05 PM
Craig F Craig F is offline
Default Re: I/O connections on a 96I/O interface
1/4" TS will be fine
I'd try and keep the cables under 10 ft. if possable
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Connetions connections connections Maxaudio General Discussion 3 09-28-2011 08:50 AM
Protools 9 Interface connections wmcgregor macOS 2 08-11-2011 01:48 PM
888/24 Connections unseen33 Tips & Tricks 4 10-18-2006 06:06 AM
HDD and CD connections Mike Emerson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-06-2002 08:55 PM
is there a digital only i/o interface compatable with digi interface connections? Felix Tips & Tricks 2 10-22-2001 10:50 PM
