Old 01-23-2008, 11:59 AM
Sam Yin Sam Yin is offline
Default When press play the stop key lite and play key blinking
I am having a problem that is when I try to play, the stop key goes on and also with blinking play key. could some one help me with this. I am in the middle of job.
system with PT HD 7.4 with Control 24 Mac 10.4.9
Old 01-23-2008, 03:01 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: When press play the stop key lite and play key blinking
Open your session. Go to your "Setup Window" (up top), click the "Playback Engine" tab, change your "H/W Buffer Size" to anything other than what it is. Click "OK". Press play, stop. Now, do the same procedure, and put the buffer size back to whatever you had it before. I don't know why, but this fixes the problem.
Hope that was the issue you had. Good luck.
-Ryan
-Ryan Young
•Pro Tools 12.6 (x2)
•OSX 10.11 & 10.12
•Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon (x2)
•16 GB 1333 MHz DDR3 (x2)
•HD Native PCIe (x2)
•HD Omni (x2)
•192 i/o
•96 i/o
•4 Seagate Barracuda 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
•Blackmagic Intensity Pro (HDMI)
Old 01-24-2008, 01:30 PM
RCSS RCSS is offline
Could your transport be online? The online button all the way on the left of the transport
Old 02-04-2008, 07:47 AM
TCDet TCDet is offline
Option>Spacebar turns this on/off BTW (On-Line).
Note: It sound more like bug where Mr. Young's solution should resolve.
I've only hit this on a G5 with LE 7.3.1x (002r)
Old 02-11-2008, 10:58 PM
sleadley sleadley is offline
This is more likely the countoff is turned on in the Transport window. Open the Transport window and show Expanded view of the window from the Views, then turnoff the countoff. Should fix the problem
Simon L.
Plan for the worst, Hope for the Best.
www.trackdown.com.au
Old 02-12-2008, 03:12 AM
.. or hit the numeric keypad's 8 key.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-05-2009, 08:26 PM
Reesho Reesho is offline
-Ryan
This problem persists and apparently only solved by the buffer size change. It's been a while so....what's up with that DIGI???
Mac Pro 2x2.8 Ghz Dual Quad-Core Intel Xeon
14 GB Ram
OSX 10.6.8
PTLE 8.0.5
Digi 002R
Midi Controller =M-Audio Axiom 49/USB2
Blinking STOP/PLAY transport buttons PLAYBACK ISSUE guitarman6 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 27 08-14-2019 12:26 PM
Press PLAY and STOP button lights! ronlosangeles Pro Tools M-Powered (Win) 0 11-29-2011 10:19 AM
Big Click/Pop when I press STOP and sometimes PLAY thegun macOS 1 09-04-2011 12:01 PM
I press play, it doesn't play. hehe - any advice? awritersparadise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-11-2007 05:24 AM
When I press play, stop is pressed as well? Charedj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-30-2006 03:06 PM
