Old 03-22-2019, 12:43 AM
rockville rockville is offline
Default Save Copy As
When I use save copy as with audio files checked everything appears to work, the progress bars take a few minutes, the new folder has the ptx file plus the audio files which are quite large, around 12 gig each as I'm sub dividing a live recording into sessions for each song that will be edited and consolidated.
The problem is when I open the session the clips are in italics though when I click open in browser they go to the correct 12gig file but they wont automatically or manually link, even though the file ID is correct for the files.
I have tried saving to another drive and trashing preferences with no luck. Any ideas?
Old 03-22-2019, 06:59 AM
Ben Jenssen's Avatar
Default Re: Save Copy As
I'm not shure I understand what the exact problem is, but this is what I used to do in similar situations:
- cut all audio other than the song I want to have in a separate session.
- consolidate that clip so it turns into a separate audio file.
- "select unused audio" in the audio clip bin menu and remove. (You should now have just the new song file in the clip bin.)
- now "save copy as..." and include audio files.
- close session WITHOUT SAVING.
(You should now have a separate session folder with just the song file in its audio files folder.
- reopen the original session and repeat with each song.
Old 03-22-2019, 08:44 AM
What's going on in the task manager when you open these sessions?
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 03-23-2019, 07:59 AM
Thanks Ben, I am almost doing the same as you I think except I first save everything in save as copy then do the cutting up, deleting and consolidate.
Old 03-23-2019, 08:02 AM
Rich, in the task manager the CPU is steady at 6% and the disk is 0% so it doesn't look as if if it just taking a long time because of the file length if that was what you were thinking, cheers
Old 03-23-2019, 08:37 AM
No, not System Usage, *Task Manager* (option-'). Want to make sure there's nothing squirrely going on there, or that perhaps EA renders are being rebuilt. And have you tried the "save copy in" to a different drive to be sure it's not some format issue? And can you give us some more system/software info?
Save Session Copy doesn't copy all files within the bin anymore Farhoof Pro Tools 12 13 11-27-2015 09:11 AM
SAVE COPY IN bounce file nor .mov copy saved ronjohn333 Pro Tools 11 1 10-01-2015 12:46 AM
"Save Session Copy in" occasionally doesn't copy.. Willard Pro Tools TDM Systems (Mac) 0 03-06-2007 12:31 AM
save sesssion copy x copy folder to another HD Alécio Costa Pro Tools TDM Systems (Mac) 6 10-22-2002 09:29 AM
"Save Session Copy" MUST copy AIIFF files??? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-11-2001 12:33 AM
