Old 12-18-2015, 03:11 AM
Default 11.3.2 auto-switching keyboard language?
on my system PT seems to auto-switch my German keyboard layout to US all the time. Even when I delete the US-keyboard from the list of available input-devices and only have the German one available to the OS it will switch back to US after working a while in PT.
This is the first time I've seen this ever since I started on PT5.x.
I noticed that as soon as I enter text to name something (marker, track, bus etc.) the keyboard language switches to US. Drives me crazy!
It seems to have started after installing 11.3.2 but it also happens on OS-level so it could well be the OS doing it globally. Is there a setting somewhere that causes this to happen?
Anyone else seeing this?
Thanks!
Frank.
Old 02-05-2016, 12:36 AM
ThierryGauthier's Avatar
ThierryGauthier ThierryGauthier is offline
Default Re: 11.3.2 auto-switching keyboard language?
I have the exact same problem here, but with French-Canadian input. Really annoying. Im still searching for an solution...
Old 05-10-2016, 11:47 PM
marcelkavka marcelkavka is offline
same with me. But PT 10 and OS 10.9.5. No solution until now...
Old 05-23-2016, 06:46 AM
Finally I fixed it this way:
To resolve this issue, ensure that your custom keyboard layout is put under /Library and not /Users/You/Libary. After moving the file, remove the input source from the list, reboot and then put it back again.
Old 03-16-2017, 05:30 PM
Its interesting, but I have nothing un both Library/keyboards layout folder? Sorry but, what is the «custom keyboard layout» Thanks
www.thierrygauthier.com
Old 03-28-2017, 12:37 PM
Stig Eliassen's Avatar
Originally Posted by Frank Kruse View Post
Thanks!
Frank.
Me too. I don't get it. It drives me nuts when I start to write something in Norwegian, and it becomes "s[ret%&/".
Old 09-06-2018, 07:55 AM
czarnekci czarnekci is offline
Hello
It seems I have the same problem here. Did you find how to fix it? maybe it's coming from the language chosen? (I'm French but working on protools in English)
Thanks
Old 11-22-2022, 12:18 AM
mups mups is offline
Hello,
Just checking if someone has solved this annoying issue...
I'm using PT 12.6.1 in english with a french MacBook Pro.
Pro Tools 10 HD3 - Apple Mac Pro 1.1 - Mac OS 10.9 - Digidesign 192 Black Lion mod - Apogee AD-8000 + AMBUS HD
Euphonix MC Mix - Audient Centro - APS Coax - Avantone Mixcube - Acoustic Energy AE22 passive - Neuman KH310
Pro Tools 12-2018 - Apple Mac Pro 5.1 - Mac OS 10.13 - EGO-SYS WaveTerminal U2A
Pro Tools 12.6 - Apple Macbook Pro 2015 - Mac OS 10.11 - RME Fireface 802
Trouble with input source/keyboard language [SOLVED] marcelkavka macOS 2 11-05-2014 11:08 PM
Cannot switch input language/keyboard layout when I start PT as admin Kirby B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-02-2010 11:04 AM
Keyboard language/Layout lode 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-12-2007 02:20 AM
Automatic switching of language GrooveEntertainment General Discussion 1 08-17-2002 10:57 PM
