Hey all,
Thanks for your help in advance. The issue: I have a two hour performance that was recorded on a GoPro and an external hard disk recorder. The GoPro split the performance into multiple files of 4GB each. My goal is to be able to sync and mix the audio in Pro Tools. In order to work to the videos in Pro Tools, I have used Shutter Encoder to convert them to DNxHD. However, the resulting files, after conversion, are 34GB each (4GB before conversion). Is this normal? Any advice for managing the file size, but still being able to work with the video in Pro Tools? Thanks! C. |
My DNXHD36 has 13 GB for 44 Minutes
Did youchoose the right quality setting? Ale
PT HD Ultimate 2020.11 6/12-Core Westmere/ 48 GB / OS 10.13.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2020.11 / MacMini Server late2011 / 16 GB / OS 10.13.6 / 002 Last edited by Ale; 11-09-2020 at 06:13 AM. |
see picture
But what are your framerates you have recorded with gopro?
PT HD Ultimate 2020.11 6/12-Core Westmere/ 48 GB / OS 10.13.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2020.11 / MacMini Server late2011 / 16 GB / OS 10.13.6 / 002 |
I honestly don't know. I left it as Type: 120 (which is the default setting for Shutter Encoder). The directions in the avid knowledgebase don't mention that setting at all... It only says to choose DNxHD and select "Generate in OP-Atom Format"
![]() Quote:
I just don't understand how a relatively high/native format could be converted to what's described as a "lossy" format and then have the file size grow so drastically... Thanks again for all the help. |
Hi
I am not familiar with what frame rates you work in US. Assuming that 30 Frames are normal you double your data if you work with 60 frames, And then when you choose a higher (unneccesary) quality setting (as it is 120) you further increase the already doubled size about 3 times. To lower your data and make PT run snooth: First you should choose a lower datarate so you keep the 60 frames if you need. You could also skip every second frame in the advanced features of Stutter encoder and change the video to 30 Frames. Ale
mp4 to DNxHd - File size 10x larger | blizzard | Post - Surround - Video | 9 | 02-19-2015 07:08 AM |
Question: Converting an audio drum file to a MIDI file? | ctyelvis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-18-2010 06:56 AM |
Update on MP3 huge file size problem | globaleric | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-09-2006 03:34 PM |
Converting Digidesign WAV File to iTunes WAV File | musicalgenius | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-19-2005 05:48 PM |
extracting/converting ProTools file to mp2 file? | jocnsoc | Pro Tools TDM Systems (Mac) | 0 | 01-30-2004 01:08 PM |
