Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 09-23-2015, 05:01 AM
Jamesr4ar Jamesr4ar is offline
Default Re: Pro tools first error
Originally Posted by DigiTechSupt View Post
This is typically seen on Mac systems where permissions are set incorrectly.
-Get Info on the Pro Tools folder in Documents
-Set Privilege it to Read & Write for your user account. (Check the Project Cache folder inside the Pro Tools folder to make sure the change was applied)
Best Regards,
YD
I don't have a 'Pro Tools' folder in my 'Documents' folder.
I installed Pro Tools First and cannot get past the
"Could not create a new document because Permission denied (13) while creating "Pro Tools" while creating "Project Cache" while creating "2Ng3RcrKknxQXUrpGMR4Ed" while creating "raKgJFFOandI7OqN8V8o6b.ptproject".
error messages.
I repaired disk permissions on my system disk.
I made sure my user was assigned read & write permissions for everything inside the Pro Tools First.app in 'Applications'.
Nothing.
Nada.
Any time frame for when this will this be sorted out?
I really wanted to try Pro Tools for its audio chopping and this was going to be my first tryout to see if Pro Tools would fit into my very heavy use of audio slicing and manual wave clip file manipulation.
Thanks
late 2011 i7 mbp, Mavericks 10.9.5, RME Fireface 800, Pro Tools First (eventually I hope)
Old 10-01-2015, 10:01 PM
NEMA515 NEMA515 is offline
Best Regards,
YD
Oh my god it worked. I swear I checked this folder's permissions a thousand times, and I decided to check it once more after I posted this.
Finally.
With all these bugs, they should call it:
Pro Tools First Bad Impressions Suck-fest.... hahaha
Old 12-07-2015, 11:10 AM
Tero Tero is offline
I am wondering, why software called Pro Tools First, is more difficult to get into working order than PT HD system with interfaces and cables.
Secondly I am wondering, why there is to blame some other company with "known issues", and blaming that user has set his/her permissions incorrectly. It is Avid software and malfunctions are in the software.
If I recommend this program for any of my students, it needs to be bullet proof to install and operate. It is the first time they deal with installing any DAW. Do you really think it is good thing for ProTools, that its lamest version is horrible from the day one.
Old 12-07-2015, 07:53 PM
ChrisG100 ChrisG100 is offline
It looks best to hold back for 8-9 months, let the devs pick this up with a sensible test and fix schedule, it cant be representative of an operating DAW, surely ?
Old 09-20-2016, 12:22 AM
lipatovroman lipatovroman is offline
Best Regards,
YD
I have same issue
I have checked permissions and set them Read & Write for all users for all folders inside!!!
But Pro Tools still displays error.
  #16
Old 06-02-2017, 05:15 AM
pdetti pdetti is offline
Here we are another 10 months later and this error still plagues many of my students who are using PT First. Does anyone have any insight to fix this error?
  #17
Old 06-02-2017, 07:27 AM
Just switched to Logic Pro X.
No crashes, no errors, faster.
Pro Tools 11 activation error-licensing service not running error message Seismic Sound Windows 5 03-23-2015 05:35 AM
Pro Tools 8: Activation code not working/Error: Data Error (cyclic redundancy check) Mattmattmatty Windows 2 05-01-2013 04:26 AM
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. kieran.mia macOS 1 01-29-2013 01:39 AM
Pro Tools Creative Collection returned an error. Error: -2147213312 sirprotools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-24-2011 06:17 PM
Pro Tools Creative Collection returned an error. Error: -2147213312 THAPRODUCERZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-05-2010 02:14 PM
