Enable MIDI voicing
Hello.
Is it possible to enable MIDI voicing in a MIDI track? I want to assign some notes to voice 1, some to voice 2, some to voice 3. The reason for it is that the export in Sibelius is more efficient. Any other solution is welcome. |
Re: Enable MIDI voicing
I believe that Event (menu) > Event operations > Select/Split notes will do what you want?
There is a way to do it in one track if the notes are not in a chord and that is via patch changes where one wants the sounds to change. Trying to do patch changes inside a chord gets real messy and may not work right. |
Is it possible to select notes, and by a command move them to another track? |
Check out the event operation I mentioned. You can split notes to new tracks based on a set pitch criteria.
Question about voicing... | dtrusz | Pro Tools TDM Systems (Mac) | 4 | 06-05-2008 09:36 PM |
PT6 AND AUTO VOICING | QXR987 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-17-2003 12:22 AM |
voicing | Dr. J | Tips & Tricks | 3 | 08-23-2001 09:22 PM |
Extra Midi Out to enable 32 midi channels | marka123 | MIDI | 1 | 02-12-2001 08:54 AM |
