digi dither preferences
hi. do you know how to change the dither plugin in the preferences window? I'd like to change the default (digidesign dither) with another. thank you!
Studio Fuoriporta - Italy... verily everywhere... |
Re: digi dither preferences
A couple of clarifying questions since I'm not near a system:
1. Where does this particular dither (that is referenced in the preferences) get used in the mix? 2. Why do you want to change it? Nika
Digital Audio Explained Now on sale! |
Hi. I think it's used to dither during bounce, and I'd like to change it because I don't like digi dither.
1. Used to dither from what bit depth to what bit depth? Is this the dither that gets us from 48 bit to 24 bit? Or is this the dither that gets us from 24 bit to 16 bit?
2. Why don't you like it? Nika
-Robert
www.extensivemusic.com |
What is the dither you prefer?
Powermac 9600/300 768mg ram OS 9.1.2, PTmix3 V5.1.3, 888/24, Adatbridge, 882/20, PSX-100, BigBen MacBookPro 1.8ghz 2gig ram OSX tiger, Mbox2 PT V.7 |
Nika
It says clearly (in the prefs.): AudioSuite Dither. I think it is used for fades too.
BTD dither is controlled from the master fader insert
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
I'm pretty sure that the Digi Dither is also used for all internal bit-depth reductions in the mix and aux busses, including faders, pans, etc. Therefore, this dither DOES have an effect on a bounce - especially one that stays at 24 bits. This type of bounce has Digi Dither all over it.
Is the question specifically regarding dither down to the 16 bit level? If that is the case then it definitely only happens with a plug-in of choice that the user puts on the master bus. But this isn't to say that this negates all of the uses of Digi Dither that happen internally. Capiche? Nika
system preferences can not find digi 002 | mato | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-22-2012 08:18 PM |
question about audiosuite dither setting under processing preferences | collinsylex | Pro Tools 9 | 4 | 03-11-2011 11:36 AM |
Deleting your Digi databases and preferences? | jackp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-31-2007 05:48 AM |
LE preferences:processing:dither? | Eric_J | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-04-2006 09:12 AM |
Digi preferences | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-08-2001 07:46 AM |
