Old 11-18-2000, 09:43 PM
beau beau is offline
Default how can i get these drum sounds
i'm trying to get that classic phil collins drum sound. another example would be on the new third eye blind recording. the chorus of the song called "deep inside of you" has these drum sounds also.
my question is, what settings on what plugins will achieve a sound similar to the one i have mentioned.
thanks in advance
beau
Old 11-19-2000, 03:01 AM
Tweakhead Tweakhead is offline
Default Re: how can i get these drum sounds
They used a lot of the AMS RMX16 unit on those records. The NonLin2 setting was the most popular.
The closest PlugIn to that piece of hardware is the D-Verb.
Old 11-19-2000, 10:48 AM
thanks tweekhead,
if anyone has any settings that have worked successfully, i'd appreciate them greatly.
thanks again,
beau
Old 11-19-2000, 03:28 PM
Marc Edwards Marc Edwards is offline
Are you after the sound source, or processing technique? Most of the Phil Collins records I've heard use a Roland TR808 drum machine--you should be able to get samples of this from a good drum machine sample CD (the sample cell cds have some nice ones).
Cheers, Marc.
Old 11-19-2000, 05:39 PM
I just remembered what else was popular back then.....mixing in triggered Simmons Kit toms with the real toms. The real toms provided the 'smack' and the Simmons toms provided the deep 'oooo' and slight bend on the pitch.
If you search the web I am sure you can find some samples of these somewhere.
Add a bit of D-Verb on nonlin mode (far right button) and you should be pretty much there.
Old 11-19-2000, 11:07 PM
Eric.D Eric.D is offline
Phil Collins is a major gated reverb man,
Try different large room efx in combo with
a fast gate like the Drawmer plugin, ect..
Eric
www.peaksound.com
Drum Sounds dizzove Tips & Tricks 3 10-23-2006 07:36 AM
OT: Drum Sounds $$$ Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-11-2003 05:32 PM
Pop drum sounds tboneatirc Tips & Tricks 1 11-28-2001 10:06 PM
drum sounds ronniemac4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-07-2001 07:13 AM
drum triggers and sampled drum sounds SNAPPER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-05-2000 11:11 AM
