Old 07-11-2011, 08:35 AM
jacknprewitt jacknprewitt is offline
Default Error Msg: "Pro Tools does not support unmapped network drives"
Hey all!
I'm sure this just a Dumb-End-User question.
I have Pro Tools LE 8 on my old PC running Windows XP Pro, SP3 with the 002R interface. (FYI---I have migrated to ProTools 9 on a MacBook Pro---which is far more stable! But I need to migrate a few sessions from the old PC system to the Mac.)
I had in mind to use "Save Copy of Session in" and copy all the session files plus the audio tracks to a blank CD that is loaded onto my CD-R/DVD-R internal drive. But when I go to run the "Save Copy of Session in" command to copy the session to the CD, I get the following error message: "Pro Tools does not support unmapped network drives"
Any suggestions?
Thanks so much,
Jack Prewitt
Rochester, NY
Old 07-11-2011, 09:11 AM
ondruspat ondruspat is offline
Default Re: Error Msg: "Pro Tools does not support unmapped network drives"
A blank CD is by definition a "unmapped" drive so you can't copy directly to it. Either "Save Copy of Session in" into a folder to burn after copying or just drag your original session folder on to the blank CD (if it fits).
"Sometimes having limits keeps you sane"- Albee1952
Old 07-11-2011, 10:14 AM
Thanks for the quick response.
I had a feeling it was fairly straight forward. Since my old sessions have mostly MIDI data and very little audio---and the audio files are located on a 2nd disk---I will copy to a new folder on the HD and then burn a data CD from there.
Best regards,
Jack
Help! massive problems with "Unmapped Network Volumes" lriley Pro Tools SE and Essential (Win) 0 05-06-2012 05:04 PM
MC Mix connects correctly first time, "Network Error" after power cycle. A Chapman Artist Series 4 07-18-2011 03:04 PM
why do I get a "protools does not support unmapped network volumes? oterrero Pro Tools SE and Essential (Win) 1 03-18-2010 09:53 AM
Pro Tools does not support unmapped network volumes?...HELP! dm3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-21-2010 09:12 AM
Error: Pro Tools does not support unmapped network elv1s1sal1ve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-27-2006 04:51 AM
