Old 06-27-2006, 08:23 PM
SMO500 SMO500 is offline
Default Firewire led on front panel is red!!!!
The firewire 1394 red indicator led on the front panel on my DIGI002 came on after I got the CANNOT LOCATE HARDWARE message. Does anybody know what this might indicate. And is there any solution without having to send in the actual unit to get fixed. Or am I screwed?
Old 06-28-2006, 12:56 AM
DJ Insomaniac DJ Insomaniac is offline
Default Re: Firewire led on front panel is red!!!!
Have you emailed Tech support?
Sam Ejnes
Re-recording Mixer
samejnes.com | IMDb | Analog Jitter
Old 06-28-2006, 03:33 AM
JFreak's Avatar
JFreak JFreak is offline
you have PowerHarnessTrouble(tm)
Janne
Old 06-28-2006, 08:35 AM
OK, what do I do
Old 06-29-2006, 01:17 AM
JFreak's Avatar
You can try to fix it yourself or send your unit to Digidesign for service (which you have to do anyway if the self-fix does not work). It is easy if you have a screwdriver
1) remove all cables and open the case
2) locate the power harness cable: it is the one that has multiple wires going from the power supply to both digital and analog boards.
3) re-seat the white plastic connectors even though they appear to be connected
4) close the case and power up
Hopefully it works; however it will likely break again at some point.
Janne
Old 06-29-2006, 01:22 AM
Musick Musick is offline
OK, what do I do
Call Digi, they will send you what you need.
I had the same exact problem, gave them a call, and in 3 days I got it and was able to replace what was wrong...
Not too bad, they know is their fault...
How do I select the mic input on the front panel...got it! Sam C Eleven Rack 0 01-17-2012 02:13 PM
Front Panel DI on 003+ not working. azuraman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-13-2009 03:29 PM
OT, different colored front panel for 001 ???? Bob Legs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 07-19-2003 12:33 AM
front panel gain closeriget 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-05-2001 09:45 PM
Unity gain on 001 front panel inputs Percustard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-29-2001 10:53 PM
