Old 01-12-2006, 03:43 AM
crizdee's Avatar
crizdee crizdee is offline
Default Massenburg design works users, can you test 4 me
users of MDW & 7.1cs2
Can you instantiate a MDW in your session and then adjust the HW buffer in the playback engine, then return to your session! (save session before testing!!)
in my session i get this message...
"pro tools is unable to reacquire the hardware because it is in use by
another application. please quit other application and hit ok, if the
hardware cannot be acquired please press quit"
Thanks, Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 01-12-2006, 10:13 AM
crizdee's Avatar
Default Re: Massenburg design works users, can you test 4 me
Anyone? Digi?
Producer, Engineer,
www.ukmastering.com
Old 01-12-2006, 10:30 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
yup ... its a bug. Exactly the same here.
Ainslie
G4 MDD 1Ghz, 2GB Ram, X.4.3, PT 7.1cs2
http://www.ainsliegrosser.com/
2013 MacPro 6 x 3.5 32GB OS10.14.4 HDX2 Sonnet Chassis, PT2019.5. Macbook 2018 Watch this to follow mobile mix studio build coming: https://youtu.be/cbqMTjCVj9I
Old 01-12-2006, 01:38 PM
rtcstudio rtcstudio is offline
Yes, and after clicking QUIT you get a DAE error message.
While they are at it, whoever fixes things at MDW, perhaps they can also fix the 48k bug where intermittantly MDW EQ's will come up in a recalled session as extreme lo pass filters (effectively muting the audio), or not passing audio at all.
Good luck getting either MDW or DIGI to respond on this. I've tried several times to get either of them to address the 48k bug. George M. is aware of it as well.
Pro Tools 10/11 HD, Mac OS 10.8.2, Mac Pro 2 x 2.4 GHz 6-Core Intel Xeon (June 2012) 64 Gig RAM, Avid HDX Card, OMNI HD I/O, 192 HD 16x16, Artist MC Control, Firewire audio drives, Sony Bravia 42" HDMI monitor, Acer 24" monitor
Old 01-12-2006, 02:37 PM
roberts roberts is offline
Bug here too!!!! Reproducable
Old 01-23-2006, 06:07 PM
jeffro's Avatar
jeffro jeffro is offline
Sorry, but I still cannot reproduce this problem. I tried changing Playback Engine settings in 7.1 and 7.1cs3 (on 1 HD Core with a 96i) with MDW EQ 1.4 installed and I did not get an error. Maybe we can narrow this down a bit...
1) Does the problem happen for you with 'stock' digi Plug-Ins + MDW EQ? If not, what other Plug-Ins (with versions) do you have installed?
2) Does it happen without a session open? If not, what are your session settings?
Old 01-23-2006, 06:17 PM
Matt_G Matt_G is offline
You may also want to ask what sample rate they are working in too or whether they are running external sync. I have had some problems with hard bypassing plug-ins & or moving them from one insert to another. It brings up this error "wmDspServer.:disableTask - Error doing DSP function call" I've done digi's hardware test which passes fine, reinstalled Protools & trashed all prefs & rebuilt permissions but I still have this problem from time to time. I first noticed it in Protools 7.1cs2, I've since tried 7.1cs3 with the same problems, version 7.0 still seems the most stable for me.
Matt
Mastering Engineer
www.matthewgraymastering.com
Brisbane Australia
Old 01-26-2006, 04:05 AM
crizdee's Avatar
I can open a new session and have only MDW and it will cause this problem!
48k 24bit session.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-02-2006, 04:14 PM
jeffro's Avatar
Is MDW the only 'non-core' Plug-In installed in the Plug-Ins folder? Can you provide a list of all installed Plug-Ins with versions?
Old 02-03-2006, 11:51 AM
crizdee's Avatar
[/QUOTE]
All 118?
Anyway, did this to test..
Just MDW and stereo mixer plugin in the folder? and the same thing plus the DAE error 1146. too many of us getting this problem!!! it must be MDW.
And your NOT getting this problem? and what about the rest of Daly City?? maybe i should move there to work! must be something in the air
Mac G5 2gig dual
4.5 gig ram
PT 7.1CS3 HD 3 ACCEL control 24
OS 10.4.3
Machine model powermac 7,2
CPU type PowerPC 970 (2.2)
Boot rom version 5.1.4f0
MDW version 1.4.0 created 25th october
Crash log below...
Report Version: 3
Command: Pro Tools
Path: /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/MacOS/Pro Tools
Parent: WindowServer [66]
Version: 7.1cs3 (7.1f58)
PID: 205
Thread: 0
Exception: EXC_BAD_INSTRUCTION (0x0002)
Code[0]: 0x00000002
Code[1]: 0x01819d00
Thread 0 Crashed:
0 <<00000000>> 0x01819d00 0 + 25271552
1 com.digidesign.ProToolsTDM 0x00439438 0x1000 + 4424760
2 com.digidesign.ProToolsTDM 0x008aa0cc dyld_stub_NewAEEventHandlerUPP + 891120
3 com.digidesign.ProToolsTDM 0x004a4f44 0x1000 + 4865860
4 com.digidesign.ProToolsTDM 0x0039306c 0x1000 + 3743852
5 com.digidesign.ProToolsTDM 0x00394e74 0x1000 + 3751540
6 com.digidesign.ProToolsTDM 0x00471ea0 0x1000 + 4656800
7 com.digidesign.ProToolsTDM 0x00486ee8 0x1000 + 4742888
8 com.digidesign.ProToolsTDM 0x0069b724 0x1000 + 6924068
9 com.digidesign.ProToolsTDM 0x003c3174 0x1000 + 3940724
10 com.digidesign.ProToolsTDM 0x003b4f50 0x1000 + 3882832
11 com.digidesign.ProToolsTDM 0x003baf54 0x1000 + 3907412
12 com.digidesign.ProToolsTDM 0x003ba600 0x1000 + 3905024
13 com.digidesign.ProToolsTDM 0x00386b28 0x1000 + 3693352
14 com.digidesign.ProToolsTDM 0x003c5b94 0x1000 + 3951508
15 com.digidesign.ProToolsTDM 0x001ea1f0 0x1000 + 2003440
16 com.digidesign.ProToolsTDM 0x001f0cd4 0x1000 + 2030804
17 com.digidesign.ProToolsTDM 0x005c6478 0x1000 + 6050936
18 com.digidesign.ProToolsTDM 0x005c62b4 0x1000 + 6050484
19 com.digidesign.ProToolsTDM 0x005c5e28 0x1000 + 6049320
20 com.digidesign.ProToolsTDM 0x001eaa4c 0x1000 + 2005580
21 com.digidesign.ProToolsTDM 0x002f0224 0x1000 + 3076644
22 com.digidesign.ProToolsTDM 0x00113d48 0x1000 + 1125704
23 com.digidesign.framework.DFW 0x01248108 TEventHandler::HandleMenuCommand(long) + 100
24 com.digidesign.framework.DFW 0x01248090 TEventHandler:oMenuCommand(long) + 52
25 com.digidesign.framework.DFW 0x01230a0c TCommandHandler:oMenuCommand(long) + 168
26 com.digidesign.framework.DFW 0x012073b0 TWindow:oMenuCommand(long) + 116
27 com.digidesign.framework.DFW 0x01248108 TEventHandler::HandleMenuCommand(long) + 100
28 com.digidesign.framework.DFW 0x01248090 TEventHandler:oMenuCommand(long) + 52
29 com.digidesign.framework.DFW 0x01230a0c TCommandHandler:oMenuCommand(long) + 168
30 com.digidesign.framework.DFW 0x01248108 TEventHandler::HandleMenuCommand(long) + 100
31 com.digidesign.framework.DFW 0x01248090 TEventHandler:oMenuCommand(long) + 52
32 com.digidesign.framework.DFW 0x01230a0c TCommandHandler:oMenuCommand(long) + 168
33 com.digidesign.framework.DFW 0x01248108 TEventHandler::HandleMenuCommand(long) + 100
34 com.digidesign.framework.DFW 0x01248090 TEventHandler:oMenuCommand(long) + 52
35 com.digidesign.framework.DFW 0x01230a0c TCommandHandler:oMenuCommand(long) + 168
36 com.digidesign.ProToolsTDM 0x002b3fb8 0x1000 + 2830264
37 com.digidesign.framework.DFW 0x01248108 TEventHandler::HandleMenuCommand(long) + 100
38 com.digidesign.framework.DFW 0x0122bd18 TApplication::MenuEvent(long, __bool8) + 80
39 com.digidesign.framework.DFW 0x0129abfc TCreditsLister:raw(VRect const&) + 1940
40 com.digidesign.framework.DFW 0x0129b41c TCreditsLister:raw(VRect const&) + 4020
41 com.apple.HIToolbox 0x93181ff4 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 692
42 com.apple.HIToolbox 0x9318174c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
43 com.apple.HIToolbox 0x931884ec SendEventToEventTarget + 40
44 com.apple.HIToolbox 0x9320105c SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 380
45 com.apple.HIToolbox 0x93231368 SendMenuItemSelectedEvent + 136
46 com.apple.HIToolbox 0x93231270 FinishMenuSelection(MenuData*, MenuData*, MenuResult*, MenuResult*, unsigned long, unsigned long, unsigned long, unsigned char) + 144
47 com.apple.HIToolbox 0x93218194 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 404
48 com.apple.HIToolbox 0x93217c7c MenuSelect + 100
49 com.apple.HIToolbox 0x93213ef0 HandleMouseEvent(OpaqueEventRef*) + 84
50 com.apple.HIToolbox 0x93217c04 StandardMenuBarEventHandler(OpaqueEventHandlerCall Ref*, OpaqueEventRef*, void*) + 56
51 com.apple.HIToolbox 0x93181ff4 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 692
52 com.apple.HIToolbox 0x9318174c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
53 com.apple.HIToolbox 0x931884ec SendEventToEventTarget + 40
54 com.apple.HIToolbox 0x93377744 HandleMouseEvent(OpaqueEventRef*) + 388
55 com.apple.HIToolbox 0x93188858 ToolboxEventDispatcherHandler(OpaqueEventHandlerCa llRef*, OpaqueEventRef*, void*) + 496
56 com.apple.HIToolbox 0x93182244 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1284
57 com.apple.HIToolbox 0x9318174c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 372
58 com.apple.HIToolbox 0x931884ec SendEventToEventTarget + 40
59 com.apple.HIToolbox 0x931c9564 ToolboxEventDispatcher + 92
60 com.apple.HIToolbox 0x931c94f0 HLTBEventDispatcher + 16
61 com.apple.HIToolbox 0x931c7aa4 RunApplicationEventLoop + 148
62 com.digidesign.framework.DFW 0x0128e950 DFW_OSEventLoop::RunApplicationEventLoop() + 16
63 com.digidesign.framework.DFW 0x0122bcac TApplication::MainEventLoop() + 16
64 com.digidesign.framework.DFW 0x0122ce00 TApplication::Run() + 56
65 com.digidesign.ProToolsTDM 0x007b5310 0x1000 + 8078096
66 0x00db9a68 0xdb9000 + 2664
67 <<00000000>> 0x00db7aec 0 + 14383852
68 <<00000000>> 0x00db770c 0 + 14382860
69 <<00000000>> 0x00db7574 0 + 14382452
Thread 1:
0 libSystem.B.dylib 0x90053f68 semaphore_timedwait_signal_trap + 8
1 libSystem.B.dylib 0x900702c8 pthread_cond_timedwait_relative_np + 556
2 ...ple.CoreServices.CarbonCore 0x90b745e4 TSWaitOnSemaphoreCommon + 176
3 ...ple.CoreServices.CarbonCore 0x90b7c580 TimerThread + 60
4 libSystem.B.dylib 0x9002b200 _pthread_body + 96
Thread 2:
0 libSystem.B.dylib 0x9000b208 mach_msg_trap + 8
1 libSystem.B.dylib 0x901043ec mach_msg_receive + 56
2 DigiMachOServices 0x035482cc DSI_GetIntMessage + 192 (icplusplus.c:28)
3 com.digidesign.framework.DSI 0x014634b0 DsiIsNPPSettingMinimized + 29944
4 com.digidesign.framework.DSI 0x01458d4c DsiRegisterStatusFeedbackProc + 72844
5 com.digidesign.framework.DSI 0x01458c78 DsiRegisterStatusFeedbackProc + 72632
6 libSystem.B.dylib 0x9002b200 _pthread_body + 96
Thread 3:
0 libSystem.B.dylib 0x900c4900 sem_wait + 12
1 com.digidesign.framework.DAE 0x0216af9c FicGetExternalDeviceDeckNameStringIndex + 18596
2 com.digidesign.framework.DAE 0x0216ad8c FicGetExternalDeviceDeckNameStringIndex + 18068
3 com.digidesign.framework.DAE 0x0216aef4 FicGetExternalDeviceDeckNameStringIndex + 18428
4 ...ple.CoreServices.CarbonCore 0x90b41a44 PrivateMPEntryPoint + 76
5 libSystem.B.dylib 0x9002b200 _pthread_body + 96
Thread 4:
1 libSystem.B.dylib 0x9000b15c mach_msg + 60
2 com.apple.CoreFoundation 0x9075d108 __CFRunLoopRun + 832
3 com.apple.CoreFoundation 0x9075ca0c CFRunLoopRunSpecific + 268
4 com.apple.audio.CoreAudio 0x914001dc HALRunLoop::OwnThread(void*) + 264
5 com.apple.audio.CoreAudio 0x913fff7c CAPThread::Entry(CAPThread*) + 96
Thread 5:
0 libSystem.B.dylib 0x90040258 mach_wait_until + 8
1 ...ple.CoreServices.CarbonCore 0x90b78ffc MPDelayUntil + 60
2 ...gn.framework.CoreFoundation 0x0156dd70 Sys_BlockingTimer::Create() + 356
3 com.digidesign.ProToolsTDM 0x007802d0 0x1000 + 7860944
4 com.digidesign.ProToolsTDM 0x0092847c dyld_stub_NewAEEventHandlerUPP + 1408160
5 ...gn.framework.CoreFoundation 0x0156d844 Sys_RawThread::GetCurrentThreadID() + 704
6 ...ple.CoreServices.CarbonCore 0x90b41a44 PrivateMPEntryPoint + 76
7 libSystem.B.dylib 0x9002b200 _pthread_body + 96
Thread 6:
0 libSystem.B.dylib 0x9002b8a8 semaphore_wait_signal_trap + 8
1 libSystem.B.dylib 0x9003001c pthread_cond_wait + 488
2 ...ple.CoreServices.CarbonCore 0x90b7f6a0 MPWaitOnSemaphore + 184
3 com.digidesign.framework.DAE 0x020cbbf0 FicSerialPortCall + 523344
4 com.digidesign.framework.DAE 0x020cb798 FicSerialPortCall + 522232
5 ...ple.CoreServices.CarbonCore 0x90b41a44 PrivateMPEntryPoint + 76
Thread 7:
2 com.digidesign.mixer.stereo 0x08c71170 CMixerAutomationTaskMain(void*) + 208
3 ...ple.CoreServices.CarbonCore 0x90b41a44 PrivateMPEntryPoint + 76
Thread 8:
2 ...gn.framework.CoreFoundation 0x0156cf98 Sys_RawSemaphorePthread::Acquire() + 136
3 com.digidesign.ProToolsTDM 0x0076ac54 0x1000 + 7773268
4 com.digidesign.ProToolsTDM 0x0076aec0 0x1000 + 7773888
5 com.digidesign.ProToolsTDM 0x0076acb4 0x1000 + 7773364
6 com.digidesign.ProToolsTDM 0x00920678 dyld_stub_NewAEEventHandlerUPP + 1375900
7 ...gn.framework.CoreFoundation 0x0156d844 Sys_RawThread::GetCurrentThreadID() + 704
8 ...ple.CoreServices.CarbonCore 0x90b41a44 PrivateMPEntryPoint + 76
9 libSystem.B.dylib 0x9002b200 _pthread_body + 96
Thread 9:
4 com.digidesign.ProToolsTDM 0x0076ace4 0x1000 + 7773412
Thread 10:
3 com.digidesign.ProToolsTDM 0x007b59a8 0x1000 + 8079784
Thread 11:
Thread 12:
2 com.apple.audio.midi.CoreMIDI 0x96969ac8 XServerMachPort::ReceiveMessage(int&, void*, int&) + 84
3 com.apple.audio.midi.CoreMIDI 0x9695cc80 MIDIInPortThread::Run() + 64
4 com.apple.audio.midi.CoreMIDI 0x96960f44 XThread::RunHelper(void*) + 28
5 com.apple.audio.midi.CoreMIDI 0x9696a87c CAPThread::Entry(CAPThread*) + 96
Thread 13:
2 ...ple.CoreServices.CarbonCore 0x90b41c34 MPWaitOnQueue + 224
3 ...gn.framework.CoreFoundation 0x015782b0 Sys_AsyncMessageQueue::Create() + 632
4 ...gn.framework.CoreFoundation 0x015bc55c Cmn_STLIterInStream<Cmn_ChunkyVectorIterator<unsig ned char, unsigned char const*, unsigned char const&> >::Read(void*, long) + 10400
Thread 14:
0 libSystem.B.dylib 0x90023420 recvfrom + 12
1 com.digidesign.ProToolsTDM 0x007b2248 0x1000 + 8065608
2 com.digidesign.ProToolsTDM 0x007b22e4 0x1000 + 8065764
3 com.digidesign.ProToolsTDM 0x007b19c0 0x1000 + 8063424
Thread 15:
2 com.digidesign.ProToolsTDM 0x007c0878 0x1000 + 8124536
Thread 16:
Thread 17:
Thread 18:
Thread 19:
0 libSystem.B.dylib 0x9002e44c kevent + 12
1 com.apple.DesktopServices 0x927eb5d4 TFSNotificationTask::FSNotificationTaskProc(void*) + 56
2 ...ple.CoreServices.CarbonCore 0x90b41a44 PrivateMPEntryPoint + 76
3 libSystem.B.dylib 0x9002b200 _pthread_body + 96
Thread 20:
3 com.apple.DesktopServices 0x927ebe20 TNodeSyncTask::SyncTaskProc(void*) + 112
Thread 0 crashed with PPC Thread State 64:
srr0: 0x0000000001819d00 srr1: 0x100000000208f030 vrsave: 0x0000000000000000
cr: 0x48022244 xer: 0x0000000000000000 lr: 0x0000000000439a54 ctr: 0x0000000001819d00
r0: 0x0000000000439438 r1: 0x00000000bfffda00 r2: 0x0000000000a0069c r3: 0x000000000b886b60
r4: 0x0000000000000001 r5: 0x0000000000000000 r6: 0xffffffffffffffff r7: 0x0000000000000001
r8: 0x000000001db562c1 r9: 0x0000000000000130 r10: 0x0000000000000001 r11: 0x0000000000000a3e
r12: 0x0000000001819d00 r13: 0x0000000000000003 r14: 0x0000000000000000 r15: 0x00000000a3181d58
r16: 0x000000001db49c30 r17: 0x00000000bfffeac0 r18: 0x00000000636d6473 r19: 0x0000000000000001
r20: 0x0000000000000000 r21: 0x0000000000bf1da0 r22: 0x000000001db52110 r23: 0x00000000140891d0
r24: 0x0000000000bf1db0 r25: 0x0000000000000001 r26: 0x0000000000000000 r27: 0x0000000000000000
r28: 0x000000001e0a7e00 r29: 0x0000000000000001 r30: 0x000000001e0aa266 r31: 0x000000000b862b80
Binary Images Description:
0x1000 - 0x974fff com.digidesign.ProToolsTDM 7.1cs3 (7.1f58) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/MacOS/Pro Tools
0xdb9000 - 0xf8076e PEF binary:
0x10d9000 - 0x10e1fff com.digidesign.framework.DMC 7.1 (7.1f58) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/DMC.framework/Versions/A/DMC
0x10e9000 - 0x10eafff FicClockComponent.dylib /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/FicClockComponent.dylib
0x1205000 - 0x132bfff com.digidesign.framework.DFW 7.1 (7.1f58) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/DFW.framework/Versions/A/DFW
0x13fe000 - 0x1426fff com.digidesign.framework.CFD 7.1 (7.1f58) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/CFD.framework/Versions/A/CFD
0x143d000 - 0x14affff com.digidesign.framework.DSI 7.1cs2 (7.1f57) /Library/Frameworks/DSI.framework/Versions/A/DSI
0x1515000 - 0x15cffff com.digidesign.framework.CoreFoundation 7.1 (7.1f58) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/CFnd.framework/Versions/A/CFnd
0x1631000 - 0x16d4fff OMFToolkit.dylib /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/OMFToolkit.dylib
0x16ef000 - 0x1744fff com.digidesign.framework.DSPManager 7.1 (7.1f57) /Library/Frameworks/DSPManager.framework/Versions/A/DSPManager
0x175e000 - 0x178ffff com.digidesign.framework.DUI 7.1 (7.1f57) /Library/Frameworks/DUI.framework/Versions/A/DUI
0x2008000 - 0x21ebfff com.digidesign.framework.DAE 7.1cs3 (7.1f58) /Library/Frameworks/DAE.framework/Versions/A/DAE
0x246f000 - 0x2660fff com.digidesign.framework.FileFormat 7.1 (7.1f58) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/FFmt.framework/Versions/A/FFmt
0x2968000 - 0x2babfff NeoAccessPro.dylib /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/NeoAccessPro.dylib
0x2c7e000 - 0x2cc2fff com.digidesign.framework.DirectIO 7.1 (7.1f57) /Library/Frameworks/DirectIO.framework/Versions/A/DirectIO
0x2eae000 - 0x2fc8fff com.digidesign.framework.DHS 7.1 (7.1f57) /Library/Frameworks/DHS.framework/Versions/A/DHS
0x3130190 - 0x3130242 CFMPriv_CoreFoundation PEF binary: CFMPriv_CoreFoundation
0x3130860 - 0x31308d7 CFMPriv_System PEF binary: CFMPriv_System
0x3130b80 - 0x3130c50 CFMPriv_CarbonSound PEF binary: CFMPriv_CarbonSound
0x3130cd0 - 0x3130da3 CFMPriv_CommonPanels PEF binary: CFMPriv_CommonPanels
0x3130e80 - 0x3130f3b CFMPriv_Help PEF binary: CFMPriv_Help
0x3130f40 - 0x313100a CFMPriv_HIToolbox PEF binary: CFMPriv_HIToolbox
0x3131090 - 0x3131166 CFMPriv_HTMLRendering PEF binary: CFMPriv_HTMLRendering
0x31311e0 - 0x31312b3 CFMPriv_ImageCapture PEF binary: CFMPriv_ImageCapture
0x3131340 - 0x3131425 CFMPriv_NavigationServices PEF binary: CFMPriv_NavigationServices
0x31314a0 - 0x3131576 CFMPriv_OpenScriptingMacBLib PEF binary: CFMPriv_OpenScriptingMacBLib
0x3131650 - 0x313170e CFMPriv_Print PEF binary: CFMPriv_Print
0x3131730 - 0x31317fd CFMPriv_SecurityHI PEF binary: CFMPriv_SecurityHI
0x3131880 - 0x3131962 CFMPriv_SpeechRecognition PEF binary: CFMPriv_SpeechRecognition
0x31319e0 - 0x3131ab3 CFMPriv_CarbonCore PEF binary: CFMPriv_CarbonCore
0x3131b30 - 0x3131c03 CFMPriv_OSServices PEF binary: CFMPriv_OSServices
0x3131ce0 - 0x3131da2 CFMPriv_AE PEF binary: CFMPriv_AE
0x3131db0 - 0x3131e75 CFMPriv_ATS PEF binary: CFMPriv_ATS
0x3131ef0 - 0x3131fc7 CFMPriv_ColorSync PEF binary: CFMPriv_ColorSync
0x3132050 - 0x3132133 CFMPriv_FindByContent PEF binary: CFMPriv_FindByContent
0x31321b0 - 0x313228a CFMPriv_HIServices PEF binary: CFMPriv_HIServices
0x3132300 - 0x31323e0 CFMPriv_LangAnalysis PEF binary: CFMPriv_LangAnalysis
0x3132470 - 0x3132556 CFMPriv_LaunchServices PEF binary: CFMPriv_LaunchServices
0x3132630 - 0x3132707 CFMPriv_PrintCore PEF binary: CFMPriv_PrintCore
0x3132710 - 0x31327d2 CFMPriv_QD PEF binary: CFMPriv_QD
0x31328d0 - 0x31329b9 CFMPriv_SpeechSynthesis PEF binary: CFMPriv_SpeechSynthesis
0x327f000 - 0x32ce3c7 CarbonLibpwpc PEF binary: CarbonLibpwpc
0x34c9000 - 0x34cafff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x3546000 - 0x3567fff DigiMachOServices ??? (7.0f57) /Library/Frameworks/DigiMachOServices.framework/DigiMachOServices
0x4016000 - 0x4028fff com.paceap.iokit.iLokSupport 5.3 /Library/Application Support/PACE Anti-Piracy/iLokSupport.bundle/Contents/MacOS/iLokSupport
0x4092000 - 0x40a0fff com.apple.iokit.IOUSBLib 2.2.5 /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x8c65000 - 0x8cb9fff com.digidesign.mixer.stereo 7.1 (7.1f55) /Library/Application Support/Digidesign/Plug-Ins/Stereo Mixer.dpm/Contents/MacOS/Stereo Mixer
0x8ef6000 - 0x8efc390 CFMHelperpwpc PEF binary: CFMHelperpwpc
0x8efc3a0 - 0x8f2b570 DSI PEF binary: DSI
0x8f2b580 - 0x8f5c80f MultiShellCode PEF binary: MultiShellCode
0x8f5c810 - 0x8f8edd1 DAE PEF binary: DAE
0x9007000 - 0x9012fff com.digidesign.framework.PlugInHelper 7.0 (7.0f171) /Library/Frameworks/DigiPlugInHelper.framework/DigiPlugInHelper
0x90cb000 - 0x917c379 MS_OLE PEF binary: MS_OLE
0x9c85000 - 0x9cccfff com.digidesign.framework.HWC 7.1 (7.1f58) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/HWC.framework/Versions/A/HWC
0x9e85000 - 0x9edafff com.digidesign.personality.Control24 7.1cs2 (7.1f57) /Applications/Digidesign/Pro Tools/Controllers/Control24.bundle/Contents/MacOS/Control24
0xac05000 - 0xac28fff com.digidesign.digidesign.DigiCoreAudioPlugIn 7.1 (7.1f57) /Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio
0xb105000 - 0xb30afff com.digidesign.AAFCOAPID.bundle AAFCOAPI version 1.0 (1.0) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/PlugIns/AAFCOAPI.bundle/Contents/MacOS/AAFCOAPI
0xb5ce000 - 0xb5cefff com.digidesign.OMF.bundle 7.0 (7.0f171) /Applications/Digidesign/Pro Tools/OMF.bundle/Contents/MacOS/OMF
0x203af000 - 0x2063dd21 MDW EQ PEF binary: MDW EQ
0x8fe00000 - 0x8fe54fff dyld 44.2 /usr/lib/dyld
0x90000000 - 0x901b3fff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x9020b000 - 0x9020ffff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x90211000 - 0x90264fff com.apple.CoreText 1.0.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90291000 - 0x90342fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90371000 - 0x906aefff com.apple.CoreGraphics 1.256.27 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9073a000 - 0x90813fff com.apple.CoreFoundation 6.4.4 (368.18) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x9085c000 - 0x9085cfff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9085e000 - 0x90960fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x909ba000 - 0x90a3efff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90a68000 - 0x90ad6fff com.apple.framework.IOKit 1.4 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90aed000 - 0x90afffff libauto.dylib /usr/lib/libauto.dylib
0x90b06000 - 0x90dddfff com.apple.CoreServices.CarbonCore 671.2 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90e43000 - 0x90ec3fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f0d000 - 0x90f4efff com.apple.CFNetwork 10.4.3 (129.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90f63000 - 0x90f7bfff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x90f8b000 - 0x9100cfff com.apple.SearchKit 1.0.4 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91052000 - 0x9107bfff com.apple.Metadata 10.4.3 (121.20.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9108c000 - 0x9109afff libz.1.dylib /usr/lib/libz.1.dylib
0x9109d000 - 0x9125ffff com.apple.security 4.2 (24844) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x91362000 - 0x9136bfff com.apple.DiskArbitration 2.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91372000 - 0x91399fff com.apple.SystemConfiguration 1.8.1 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x913ac000 - 0x913b4fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x913b9000 - 0x913d9fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x913df000 - 0x913e7fff libbsm.dylib /usr/lib/libbsm.dylib
0x913eb000 - 0x91469fff com.apple.audio.CoreAudio 3.0.1 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x914a7000 - 0x914a7fff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x914a9000 - 0x914e1fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x914fc000 - 0x915c9fff com.apple.ColorSync 4.4.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9161e000 - 0x916b1fff com.apple.print.framework.PrintCore 4.3 (172.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x916f8000 - 0x917b5fff com.apple.QD 3.8.18 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x917f3000 - 0x91851fff com.apple.HIServices 1.5.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9187f000 - 0x918a3fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x918b7000 - 0x918dcfff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x918ef000 - 0x91931fff com.apple.LaunchServices 10.4.5 (168) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9194d000 - 0x91961fff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9196f000 - 0x919a8fff com.apple.ImageIO.framework 1.4.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x919bd000 - 0x91a83fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91ad0000 - 0x91ae5fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91aea000 - 0x91b06fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b0b000 - 0x91b7afff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91b91000 - 0x91b95fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91b97000 - 0x91bc8fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91bcc000 - 0x91c0ffff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91c16000 - 0x91c2ffff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91c34000 - 0x91c37fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91c39000 - 0x91c39fff com.apple.Accelerate 1.1.1 (Accelerate 1.1.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91c3b000 - 0x91d25fff com.apple.vImage 2.0 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91d2d000 - 0x91d4cfff com.apple.Accelerate.vecLib 3.1.1 (vecLib 3.1.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91db8000 - 0x91e1dfff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91e27000 - 0x91eb9fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91ed3000 - 0x92463fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x924ab000 - 0x927bbfff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x927e8000 - 0x92874fff com.apple.DesktopServices 1.3.1 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x928b6000 - 0x92ae0fff com.apple.Foundation 6.4.2 (567.21) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92bfe000 - 0x92cdcfff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x92cfc000 - 0x92deafff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92dfc000 - 0x92e1afff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92e25000 - 0x92e7ffff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92e9d000 - 0x92e9dfff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92e9f000 - 0x92eb3fff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92ecb000 - 0x92edbfff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92ee7000 - 0x92efcfff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92f0e000 - 0x92f95fff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92fa9000 - 0x92fb4fff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92fbe000 - 0x92febfff com.apple.openscripting 1.2.3 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x93005000 - 0x93015fff com.apple.print.framework.Print 5.0 (190.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x93021000 - 0x93087fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x930b8000 - 0x9310afff com.apple.NavigationServices 3.4.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x93136000 - 0x93153fff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x93165000 - 0x93172fff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x9317b000 - 0x9348dfff com.apple.HIToolbox 1.4.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x935d9000 - 0x935e5fff com.apple.opengl 1.4.6 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x940bf000 - 0x94189fff com.apple.audio.toolbox.AudioToolbox 1.4.1 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x941dd000 - 0x941ddfff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x941df000 - 0x94357fff com.apple.QuartzCore 1.4.3 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x943e6000 - 0x94436fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x945d8000 - 0x945e7fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x945ef000 - 0x945fbfff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x94640000 - 0x94658fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9465f000 - 0x948c1fff com.apple.QuickTime 7.0.0 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94994000 - 0x949b3fff com.apple.vecLib 3.1.1 (vecLib 3.1.1) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x94d7e000 - 0x94d9bfff libresolv.9.dylib /usr/lib/libresolv.9.dylib
0x9695c000 - 0x9699bfff com.apple.audio.midi.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x974fd000 - 0x9750afff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x98880000 - 0x99012fff com.apple.QuickTimeComponents.component 7.0 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x99e61000 - 0x99e7ffff com.apple.OpenTransport 2.0 /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
0x99efa000 - 0x99efbfff com.apple.iokit.dvcomponentglue 1.7.5 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0x9b007000 - 0x9b08afff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
Model: PowerMac7,2, BootROM 5.1.4f0, 2 processors, PowerPC 970 (2.2), 2 GHz, 4.5 GB
Graphics: GeForce FX 5200, GeForce FX 5200, AGP, 64 MB
Memory Module: DIMM0/J11, 1 GB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM1/J12, 1 GB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM2/J13, 512 MB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM3/J14, 512 MB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM4/J41, 512 MB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM5/J42, 512 MB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM6/J43, 256 MB, DDR SDRAM, PC3200U-30330
Memory Module: DIMM7/J44, 256 MB, DDR SDRAM, PC3200U-30330
Modem: MicroDash, Euro, V.92, 1.0F, APPLE VERSION 2.6.6
Network Service: Built-in Ethernet, Ethernet, en0
PCI Card: pci-bridge, pci, SLOT-2
PCI Card: pci11af,eed2, sppci_othermultimedia, 7x4
PCI Card: pci1057,ffff, sppci_othermultimedia, 7x5
PCI Card: pci1057,ffff, sppci_othermultimedia, 7x6
PCI Card: pci1057,ffff, sppci_othermultimedia, 7x7
PCI Card: pci1057,ffff, sppci_othermultimedia, 7x8
PCI Card: pci1057,ffff, sppci_othermultimedia, 7x9
PCI Card: pci1057,ffff, sppci_othermultimedia, 7xa
PCI Card: pci1057,ffff, sppci_othermultimedia, 7xb
PCI Card: pci1057,ffff, sppci_othermultimedia, 7xc
PCI Card: pci-bridge, pci, SLOT-3
PCI Card: pci11af,eee1, sppci_othermultimedia, 8x4
PCI Card: pci1057,ffff, sppci_othermultimedia, 8x5
PCI Card: pci11af,eee1, sppci_otherbridge, 8x6
PCI Card: pci-bridge, pci, SLOT-4
PCI Card: pci11af,eee1, sppci_othermultimedia, ax4
PCI Card: pci1057,ffff, sppci_othermultimedia, ax5
PCI Card: pci11af,eee1, sppci_otherbridge, ax6
Serial ATA Device: Maxtor 6Y250M0, 233.76 GB
Serial ATA Device: Maxtor 7Y250M0, 233.76 GB
Parallel ATA Device: PIONEER DVD-RW DVR-109,
USB Device: Hub, , Up to 480 Mb/sec, 500 mA
USB Device: MS-20 Controller, KORG INC., Up to 12 Mb/sec, 500 mA
USB Device: USB Device, , Up to 1.5 Mb/sec, 500 mA
USB Device: Generic USB Hub, ALCOR, Up to 12 Mb/sec, 500 mA
USB Device: iLok, iLok, Up to 1.5 Mb/sec, 500 mA
USB Device: USB Multimedia Keyboard, , Up to 1.5 Mb/sec, 500 mA
USB Device: XSKey, Emagic GmbH, Up to 1.5 Mb/sec, 500 mA
USB Device: USB Zip 250, Iomega, Up to 12 Mb/sec, 500 mA
USB Device: vend_device, , Up to 12 Mb/sec, 500 mA
USB Device: Hub, , Up to 12 Mb/sec, 500 mA
USB Device: ShuttleXpress, Contour Design, Up to 1.5 Mb/sec, 500 mA
USB Device: USB Receiver, Logitech, Up to 1.5 Mb/sec, 500 mA
USB Device: CTF-420 V2.0-0, WACOM, Up to 1.5 Mb/sec, 500 mA
FireWire Device: LaCie Big Disk Extreme LUN 0, LaCie Group SA, Up to 800 Mb/sec
FireWire Device: unknown_device, unknown_value, Up to 400 Mb/sec
FireWire Device: Que!fire, QPS, Up to 200 Mb/sec
Producer, Engineer,
www.ukmastering.com
Process card failed Digi test, but works as far as i can tell? crizdee Pro Tools TDM Systems (Mac) 9 09-26-2009 11:34 AM
Massenburg design works users, can you test 4 ZEUSS ProControl, Control|24, Command|8 3 01-28-2006 07:55 AM
Massenburg design works users, can you test 4 me sirpucho Pro Tools TDM Systems (Mac) 0 01-14-2006 11:42 AM
Massenberg Design Works vs Sony Oxford EQ W/ GML ryan de topanga Pro Tools TDM Systems (Mac) 5 04-10-2005 06:28 PM
DIGI please design us a current config that works digi2000 Pro Tools TDM Systems (Win) 6 12-14-2001 09:24 AM
