Old 11-19-2013, 07:56 AM
yazoo yazoo is offline
Default best way to go from 23.976FPS to 24FPS with a PT mix
My session is 24b/48khz / 23.976FPS
We are about to make a DCP and need to go to 24FPS.
What is the best way to do this?
pull-up?
or time stretch in Timefactory?
regards
benny
Old 11-19-2013, 08:16 AM
Default Re: best way to go from 23.976FPS to 24FPS with a PT mix
Make a new session. Set it to 24fps. Import your Master 5.1 track and turn on SRC in the import window and chose the +0.1% pull-up preset.
After that you might have to re-align the file to make sure your 2-pop is at the correct TC
Done.
Frank.
Old 11-19-2013, 08:21 AM
Thanks will try that.
Old 11-19-2013, 09:32 AM
Done.
Frank.
The SRC and samplerate is greyd out when I try to import
File Type: jpg Skärmavbild 2013-11-19 kl. 18.30.14.jpg (49.2 KB, 0 views)
Old 11-19-2013, 09:40 AM
Sorry, I used ADD instead of copy.
Is it the NTSC -> Film that is the correct?
/b
File Type: jpg Skärmavbild 2013-11-19 kl. 18.38.34.jpg (57.2 KB, 0 views)
Old 11-19-2013, 10:11 AM
/b
Yes. 0.1% UP
HTML code is On
Using 25fps to 24fps then the converted 24fps to new 25fps. Stay with me on this! abes Post - Surround - Video 2 03-01-2013 09:36 AM
23,976fps VS 48kHz lego Post - Surround - Video 10 04-13-2009 03:43 PM
24fps to 29.97? groan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-28-2008 09:39 AM
24FPS to 29.97 minister Post - Surround - Video 12 10-06-2004 07:59 AM
Sync drift on FCP 4 23.976fps QT in PT 5.1.3 twarren Pro Tools TDM Systems (Mac) 5 01-30-2004 07:36 AM
