best way to defragment ProTools system drive?
it's running OS 9.2.1. also on the drive is OS X.
(installed as OS X with OS 9.) can i just transfer contents to another drive, then erase the original drive/partition, then replace the contents? is it better to use Disk Warrior or Norton Utilities in this case? doing the transfer thing is preferred... what's recommended? |
Re: best way to defragment ProTools system drive?
You have the joy of dealing with your authorisations (unless you got an iLok) if you start fomatting things I think, i wouldnt risk just leaving them on. I one lost one of my SDII auths ages ago re-formatting.
Carbon Copy Cloner will let you do the copy process easily though. I think X is picky about moving it, but CCC definitely works. http://software.bombich.com/ccc.html Its an X app though. I would reccomend having 9 and X on separate partitions - then its so much easier and quicker to fix up your 9 one, or flatten the X one when 10.5 comes out... then youre not upsetting the 9 partition and can carry on working... Or you can do the 'copy defreg' thing just by copying on to the other drive. I guess it depends how you do most of your work though. Were stuck in 9 till we sort the fibre channel out for X, so using X is mostly 'experimentational' for us. So Its nice to know whatever we do on that partition will never upset the finely honed 9 one. If you never use X, you might as well just get rid of it. Depends on your upgrade plans though i suppose. Sorry, getting a bit off track. I have to admit ive neglected defraging recently. For audio, if your recording on a separate drive, a Finder copy is the best ive been told. Everyone I know has been slating Norton recently, well, since v4. My mate raves about Disk Warrior for system stuff. hope this is of some use, sorry, Im a bit tired. 'best Tom |
thomoose is right about partitioning. I highly recommend it. Partitioning keeps both systems totally separate, which I think improves performance, and it's much easier to troubleshoot problems.
As far as a defragger, I use Plus Optimizer. It comes with Disk Warrior 2.1 version but not with the new 3.0 for X but it doesn't matter. Plus Optimizer will defrag an OS X volume just fine. You'll have to restart from the DW cd to run PO. |
Thomoose - you said
We have a fibre channel problem here that I've been trying to get sorted out. We need a Windows2000/OS9 solution, but we'd also like to switch to OS X in the near future. So far, the only thing I've seen is Storage Network Solutions which has a new version of software shipping in less than 2 weeks. There are some caviats that I don't have any details on as yet, but it will probably be that they want us to use their HBAs. Feel free to email me at [email protected] if you'd like to discuss this. [email protected]
Mark Reis Sound Designer |
i'm currently using partitions. i installed the OS X / 9.2.2 on my PT partition because that is the config. that Digidesign tested my G4 with.
my G4 came with a set of cd's that includes 9.2.2, but won't let me install it on it's own. can i take the OS 9 system and elements off the drive, erase the drive, and then put just the OS 9 / PT system back on. otherwise, where do i get a cd for Mac OS 9.2.2? is there anyone who's had problems running only 9.2.2 on a partition or drive with the MDD G4's? |
Mark, I'll email yhou this week.
Felix, I had a 4 card mix system in a G4 Dual 1ghz MDD, running of a 9.2.2 partition - no problems at all. The easiest way to get a clean 9 install if you have one of the first series MDDs (ie the ones that support OS9): - Make yourself a fresh partition - boot into X - Insert Restore CD 1 - Use find to search for an invisible file with "OS9" in the name on the CD. - you should find a disk image called "OS9 General.dmg" - double click this in the search results window. It should then mount. - copy the contents onto your balnk partition - boot of that partition and youve got a clean 9.2.2 system! Thats what I did with my machine, and its worked a treat. Best thing is, it only takes about 2 minutes to do. 'best Tom |
i will do this. thanks again. |
12 hours to defragment a 320 gig drive??? | paulreed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-21-2009 10:40 AM |
Does a 10,000rpm system drive help ProTools? | johnnyv | Pro Tools TDM Systems (Mac) | 7 | 04-15-2009 01:12 AM |
Anyone run ProTools LE off their Laptop System Drive? READ | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-20-2008 08:09 PM |
Firewire Drive Defragment Software? | KMAN385 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-02-2007 05:57 PM |
Defragment the drive?? | jackruston | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-13-2001 12:57 AM |
