Old 12-16-2011, 10:02 AM
davidlustrup davidlustrup is offline
Default scarlet 8i6
any opinions on whether or not the scarlet 8i6 is a good choice for PT 9? i plugged mine in and PT9 froze up a couple of times. starting to wonder if there are any known issues between the 2
Win 7 64 bit
AMD Phenom(tm) II X4 965 Processor
Mainboard : Asus M4A78T-E
BIOS : AMI 2402 01/05/2010
Chipset AMD RS780 Host Bridge
Memory 6 gigs ddr3 1600mhz
Memory OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) X 3 for 6 gigs
Video Adapter : ATI Radeon HD 4870 X2
Western Digital Black 1TB, SATA300,7200 rpm 64MB Cache 932GB For PT
WDC 500.1GB, SATA300,7200rpm, NCQ, 16MB Cache For Recording
http://www.vampirefreaks.com/dawnofblack
Old 12-18-2011, 09:59 AM
Default Re: scarlet 8i6
no one uses the scarlet then?
Win 7 64 bit
Old 12-22-2011, 12:56 AM
ok then...no one uses the scarlet 8i6. kewl
since no one uses it here, i will repost from the gearslutz forum that it is indeed a awesome interface to use with PT as many use it over there. so just FYI
Win 7 64 bit
Mbox Micro with PT 8 LE + Focusrite Scarlet 2i2 elmodagansta Windows 2 02-08-2013 02:57 AM
transfuser with protools 9 and focusrite scarlet 8i/6 zela8 Virtual Instruments 0 10-16-2011 10:27 PM
