Quicker Bounces
Is there a way to speed up the Bouncing process after a session is recorded?
Re: Quicker Bounces
Go to the audio window and highlight your stereo files and export it from the audio menu. This assumes that you have already captured the fully processed audio in a stereo audio track.
Re: Quicker Bounces
Now when you say export, where would I export to?
Re: Quicker Bounces
You will have the same export options as you do for 'bounce to disk'. In the audio window (the one to the right of the edit window). Highlite the stereo audio take (file); click (or right click?) on the top bar of this audio window and a menu will display; select 'export'. Once you have picked the format, it will ask you where you want the file to go.
Since I am not looking at your screen, I am detailing the process as complete as possible so you can get on with your work. |
Re: Quicker Bounces
Thanks for your knowledge and the help. I'm not protools savy yet....
Re: Quicker Bounces
That only saves you time if you need to do mutliple bounces at different rates or depths.
In the normal case, there's currently no way to do a fast bounce.
Quad 2.5 G5, 4.5G RAM |
Re: Quicker Bounces
I can't believe Digi still hasn't developed a more quick way to do a bounce to disk other than in real time. I understand it is done that way in order to be able to use outboard processing and FX but I think many of us do everything with plugins. I don't have a single piece of processing hardware in my studio, I'm allways with plugins so I, and I'm sure, many of us could beneficiate and save a lot of time if bouncing was improved. Lot's of semi pro apps can do it why PT can't? |
Re: Quicker Bounces
bouncing in real time is nice though....you can use external gear.
ik zei nooit dat! |
Re: Quicker Bounces
Yeah, but I still think they should make it an option one can toggle on or off..
Re: Quicker Bounces
I vote for. as an option of course.
And i will take with this a track freeze feature!!! that would be way great! |
Open ProTools Quicker | tnyquist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-06-2010 07:03 AM |
Quicker Routing through Busses | Dizzi45Z | Pro Tools TDM Systems (Mac) | 26 | 02-02-2010 09:48 PM |
Quicker, Better, Dipping and Undipping? | dcaudio | Post - Surround - Video | 13 | 02-20-2009 10:44 AM |
MD-CD can you do it quicker? | Craig Golding | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-22-2002 05:26 AM |
Quicker way to drag regions? | Zep Dude | Tips & Tricks | 2 | 10-21-2000 12:34 AM |
