No audio from my Mbox 2 mini PT 10
I just finish setting up my PT10 system on my Mac pro tower running lion 10.7.5. Everything seems to be working fine intill I added an Mbox 2 mini as my interface and I'm unable to hear any audio. The session plays and my meters are showing just no audio. Before this I was able to hear from my towers built in speaker and on head phones connected to my computer. Please tell me what I should select or do, What am I missing here
Note: I did download the latest legacy drivers from AVID for USB interfaces Mbox 2 mini. It turned the green light on and my box is listed as an interface in PT and Note : I have PT 10.0 not the 10.3.8 version Thanks in advance for any help |
Re: No audio from my Mbox 2 mini PT 10
^^^^BUMP^^^
PLEASE CAN ANY ONE HELP ME |
Go into Set-up > I/O and select default.
Make sure the Mbox is selected as the playback engine. |
Thanks but I have selected mbox mini and outputs 1 and 2
Try a different USB port on the tower and, if possible a replacement USB cable.
just so you know I am receiving power because I see the green light on in front of the mbox but I will try a different port and then I will try a different cord
I just tried using different usb ports and a new cord still to no avail. I know Im missing something here, can a fellow protooler get a hand so I can be on my way
check the mix knob on the mbox?
Ray Trujillo Freelance Audio Engineer |
If you mean the monitor knowing in the front next to the head phone knob then
Yes I have tried it |
I just find it hard to believe know one here can help me
Can't hear audio through MBox 2 Mini | MartinoAl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-06-2012 07:49 PM |
mbox mini audio isn't working | LaurenLehman954 | Pro Tools 10 | 1 | 07-01-2012 08:23 PM |
using audio buddy with mbox mini | wind was high | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-31-2011 09:13 PM |
MBox 2 Mini - No Audio Inputs Available | The Missile Silo | macOS | 0 | 02-20-2011 08:27 PM |
Can i run computer audio through Mbox 2 Mini? | timeey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 07-18-2010 09:51 AM |
