Old 12-10-2010, 07:34 AM
treef treef is offline
Default 64bit
hello, the only reason i am currently not updating from PT8 to PT9 is that i may switch from cubase 5 (or later) as soon as there is a full 64bit version, incl. adapted RTAS plug-ins. are there any news? thanks, marco
Old 12-10-2010, 08:48 AM
Becharax's Avatar
Becharax Becharax is offline
Default Re: 64bit
I heard it's gonna be released in March 2011 and I didnt update either so not to pay twice :S
Old 12-10-2010, 09:12 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: 64bit
Except for being able to use more RAM, 64 bits won't buy you much in a DAW. Yes, you will be able to use more VI but how many of you are running into problems with not enough RAM? I don't use many VI so 64 bits means little to me.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 12-10-2010, 12:07 PM
Default Re: 64bit
well, as soon as you are working with orchestral libraries, 64bit is a must just because of RAM indeed - looking forward to.
Old 12-10-2010, 12:30 PM
Carl Lie Carl Lie is offline
Default Re: 64bit
There are ways of getting around that if you want to work in ProTools.
Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 12-10-2010, 01:35 PM
Default Re: 64bit
i have been using separate machines for years, but any way around it is not as elegant as having it inside, so to say - the same counts for sibelius, actually.
Old 12-10-2010, 01:44 PM
davidlustrup davidlustrup is offline
Default Re: 64bit
so protools 9 will have a 64-bit version come march? and they are gonna charge for it?
when cubase 5 was released you got 32 and 64 bit for the price. you didnt have to pay more foro the 64 bit version
will we be able to run 32 bit plugins in it without bugs? (because i know cubase 5 is having HUGE issues with that....so much so that you have to go buy another piece of bridge software to even use 32 bit plugs in 64 bit
Win 7 64 bit
AMD Phenom(tm) II X4 965 Processor
Mainboard : Asus M4A78T-E
BIOS : AMI 2402 01/05/2010
Chipset AMD RS780 Host Bridge
Memory 6 gigs ddr3 1600mhz
Memory OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) X 3 for 6 gigs
Video Adapter : ATI Radeon HD 4870 X2
Western Digital Black 1TB, SATA300,7200 rpm 64MB Cache 932GB For PT
WDC 500.1GB, SATA300,7200rpm, NCQ, 16MB Cache For Recording
http://www.vampirefreaks.com/dawnofblack
Old 12-10-2010, 01:53 PM
Default Re: 64bit
You don't need two machines. Run your VI's through Reaper or VEpro directly into ProTools from the same machine. You can run as many instances of VEpro as you want. One for 32 bit VI's and one for 64 bit VI's if you want.
Routes each track directly into ProTools through an AUX track. Piece of cake.
Carl
Old 12-10-2010, 02:48 PM
Hotcrazyfruit Hotcrazyfruit is offline
Default Re: 64bit
So 64 Bit means little to you.
A single instance of Sample tank 2 can run over 500MB easily.
64 bit does not only increase the amount of memory available to the host computer, but also increases the amount of throughput in the CPU.
With myself only having 3 GB of RAM, i plan to upgrade. I would like pro tools to be able to use a machine to its fullest extent.
IMO, it should be here before 2012.
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20)
12 GB Patriot Viper Extreme
Asus P6T
OCZ Agility 64 GB SSD
Hitachi 1TB 32 MB HDD
WD Caviar Black 500GB
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Fender Super Champ XD
Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet
Old 12-10-2010, 02:50 PM
Default Re: 64bit
who told you that?
As much as id like to believe it, i doubt it. There is no way they would script protools 9 in 32bit, and then re write to take advantage of 64bit. It wouldn't make sence.
Nick
Asus P6T
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
[IMG] code is Off
R E A L L Y - P I S S E D - O F - A B O U T - T H E - L A C K - O F - 64bit - PT 9 Aerny macOS 25 06-06-2011 03:44 PM
about PT9 on w7 64bit ericyang1215 Windows 2 06-03-2011 02:45 AM
E.T.A On P.T 9 64bit? Steve_Brown Pro Tools 9 107 01-06-2011 04:29 PM
XP goes 64BIT AfricanCaneKing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 02-04-2005 10:24 AM
64bit XP and PTs Guit4Brains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-22-2004 09:17 AM
