Software update to 10.5.7, now M-box not seen
Any ideas? Specs are:
PB1.67Ghz/2GB RAM plenty of free HDD space. Running OSX 10.5.7. PTle 7.3, which until I did the software upgrade, worked fine. Now the M-Box (original with Focusrite pres) is not seen on the USB buss. Tried different cables, (it lights up and goes through usual power sequence) and USB port, no luck. Has Apple screwed me on this? |
Re: Software update to 10.5.7, now M-box not seen
I'm on 10.5.7 with the original Mbox with no problems, although on PT8.
I don't believe that 7.3 is compatible with Leopard - you need 7.4.2 or better. Check the compatibility chart.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Nevermind, after several reboots and a permissions repair, all is well.
7.3 might not be "officially supported" vor 10.5.7, but it is working just fine, and has been for a long time for me. |
software update | kittybite | Windows | 2 | 10-17-2012 08:52 PM |
10.5.4 in Software Update | John Jeffers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-30-2008 01:57 PM |
Software Update | DAS-Mike | Pro Tools TDM Systems (Mac) | 3 | 01-12-2008 08:33 AM |
Windows Update Vs Apples Software Update | sunburst79 | General Discussion | 2 | 07-14-2007 06:40 AM |
Implement software update option into ProTools software | Samhein | Pro Tools TDM Systems (Mac) | 1 | 07-09-2003 12:47 AM |
