Old 07-18-2003, 07:07 PM
little king little king is offline
Default it SOUNDS like a home recording
well, i have a LOT to learn about mixing, i know this, but...
today i finally stopped tweaking a mix and burned a CD. right away it was that old home recording thang- it sounded good, but i had to turn my hi-fi up to 31, which would be breaking the windows if i played, say, my James Brown CD that loud.
[img]images/icons/confused.gif[/img] how does one go about getting good levels on the final product? don't get TOO technical on me... if i'm missing something that can be found in the reference manual, please point the way...
thanks
Old 07-18-2003, 07:25 PM
cliepe12 cliepe12 is offline
Default Re: it SOUNDS like a home recording
a good place to start is by getting a Plugin like the L1 Ultramaximizer by Waves. This allows you to bring up the level while you avoid clipping.
You can also go and get it mastered by someone who knows what they are doing for sometimes pretty cheap.
Chris-
Digi001 6.4, 10.3.3, Reason 2.5, Waves Diamond v4, Yamaha 01V96, Dual 1.25 w/FW800 - 1GB, 2x120GB
Old 07-18-2003, 07:33 PM
pk_hat pk_hat is offline
We'd love to help, really, but your question is right up there with:
1- "which monitors should I get?"
2- "Mac or PC?"
There are pages upon pages of info on this DUC, just use the search function, as everyone has their way of doing things when it comes to producing, mixing and engineering, and evidently, your issues are directly related to those 3 things.
Bookmark the following, get some coffee going and you'll learn more than you ever thought possible, it's amazing...
www.digidesign.com/digizine/
www.studiocovers.com
www.sound-on-sound.com
www.futuremusic.co.uk
www.computermusic.co.uk
www.pro-rec.com
www.digido.com
www.myspace.com/krou
Old 07-18-2003, 11:02 PM
KamaSutra77 KamaSutra77 is offline
They seriouslly need a FAQ thread on the DUC. My waders are wearing out!
Huh?
Old 07-18-2003, 11:11 PM
Nitronick Nitronick is offline
<font size="2" face="Verdana, Arial">Actually, someone in the PC forum started one, and Digi made it a sticky. It's about 3 pages now. You guys might want to do the same, but with Mac related issues.
Mitch
Mitchell Benson
Linda Brown and Associates
www.lindabrownandassociates.com
Old 07-18-2003, 11:23 PM
lenf lenf is offline
A resource you might want to look into is Bob Katz' new book, "Mastering Audio, the art and the science." *Very* nicely done, takes an overall view in explaining the recording/mixing/mastering process. A fun read as well.
When I searched it out a month or so ago, I found the best price at bn.com
Old 07-19-2003, 01:44 AM
DIGIDUDE26 DIGIDUDE26 is offline
just mix it.........don't use maximizers, and don't clip anything...........then go give it to a pro ME. You will be happy that you did!
good luck
002r, Dual 1.25 G4, 1gig DDR, Dual 17 Studio Display, 12 Powerbook, HR-824's, NS-10m's Good Times!
Old 07-19-2003, 08:21 AM
where02190 where02190 is offline
2- "Mac or PC?"
<font size="2" face="Verdana, Arial">This is hardly true. The answer is simple. Recording is a 3 stage process:
1. Tracking
2. Mixing
3. Mastering
You can either:
1. learn to master on your own by researching the subject.
2. Take your fiished mix to be professionally mastered.
Hope this is helpful.
Old 07-19-2003, 09:29 AM
Fourtsian Fourtsian is offline
As a step one, import your final track and someone else's song (which is louder than your track) into PT, and see the bandwidths. I think this helps a lot.
Your track might have lots of unwanted peaks. You can get rid of those notes (with the pencil tool or something like that) and turn up the volume without compressing your track.
Hope this helps a lit bit.
Old 07-19-2003, 11:35 AM
john1192 john1192 is offline
mix, mix it again, add a little compression to the tracks that jump out too much or the ones that don't punch out enough. a little at a time. listen on different systems, reference to commercial CD's that are not extremely loud. by all means import CD's that you like and look at the waveforms but don't draw out peaks with the pencil tool. that tool is for going to sample level and removing bad pops or clicks but not for mastering purposes. in short, try making 4 different versions of your mix and putting them on the same CD. ie: vocal up (or main instrument of instrumental), vocal down, bass up , bass down. listen to your mix with and without the vocal, does it sound fine until you add the vocal ? your vocal and the other instruments may be fighting for the same space....just keep trying and tweaking a db here or there, do lots of mixes and it will start to get clearer...you need to know what you are hearing...
as far as level, as your mix becomes tighter it will get a little louder. unless you have an L1 or L2 or some hardware (Waves L2 Maximizer) or a friend that is a mastering engineer you will only be able to do so much. find someone that is a mastering engineer ( not a friend that has a big set of speakers) and ask them to liten to your mix. if you are sincere in your desire to learn, don't be embarrassed to play what you think is a bad mix for this person.
lastly, mix, mix, mix, and keep mixing
learn your monitors, play mixes on your friends systems, their cars, Good Guys boom boxes...the toaster......... [img]images/icons/smile.gif[/img]
peace john
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Getting back into home recording rangermark macOS 10 04-10-2013 01:03 PM
nu 2 Home RECORDING ~ MBOX2 pro THE 002 OR the 003 ???????? Jcverses 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-26-2007 01:55 AM
Home Recording PODCAST IHR General Discussion 3 10-06-2005 11:07 PM
OT: Home Recording Magazine Joe Evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-09-2004 01:55 AM
OT: Best Home Recording Mag. & Recording Workshop jcoker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-22-2003 07:22 PM
