Old 10-21-2019, 03:06 AM
JoTedesco JoTedesco is offline
Default D Command doesn't work
Good morning, i'm a new member i'd like to thank everyone for assistance and collaboration.
i just bought a D Command with X Mon . I connected D Command to my Mac Pro with an Ethernet cable, but the system cannot find it. I tried with all 2ethernet ports of MAc. Currently my configuration is made by a Mac Pro Os 13.13 High Sierra and Pro Tools Ultimate software updated 5/2019 with an annual subscription (i pay about 30 Chf every month ). Do I need some new drivers which are not present in PT Ultimate?
The sound card I currently use is a Focusrite18 / 20.
I mainly work as a voice over using a Universal Audio 6176 strip channel preamplifier connected to a Neumann microphone.
Many thanx
Old 10-21-2019, 03:09 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: D Command doesn't work
Hi, welcome to the community.
Search for a "D-Command Guide", the pdf has all the info you need.
Janne
Old 10-21-2019, 03:29 AM
Thanks JFreak, I did exactly as described. Is it possible that this is a problem related to my PT Ultimate software? In the Icon specifications I read that it requires PT HD.
Old 10-21-2019, 03:35 AM
JFreak's Avatar
Ultimate is a new name for HD
Janne
Old 10-21-2019, 03:46 AM
JFreak . Ok Thanks. It is possible there is a problem of firmware in ICon D Command ? Maybe an update to do ..
In another post of a member (Kdramsey) i read he had same trouble. It was a problem of CPTK (?) .
Old 10-21-2019, 04:05 AM
JFreak's Avatar
The problem may be your interface. I don't know really, just guessing, because I know nobody who uses D-Command with a 3rd party interface. Everyone using HDX or HDN
Janne
Old 10-21-2019, 06:34 AM
Logichead Logichead is offline
I would suggest a few things, not in this order necessarily!
Create a system report in “About This Mac” with D Command connected and see if it sees the device. You can also try using LanScan to see what’s connected to Ethernet.
Replace the cable. Be sure it isn’t an Ethernet crossover type of cable.
Connect another Ethernet device to the Mac to be sure the Mac Ethernet is working.
Initialize the D Command and try again.
Let us know what you find!
Best...H
Custom Key Command doesn't work planck Artist Series 0 10-15-2019 06:19 AM
Import audio command doesn't work flautista Pro Tools 11 6 04-04-2016 04:37 AM
PT10 Bug: opt-command-/ doesn´t always work Frank Kruse Post - Surround - Video 2 01-13-2012 05:29 AM
Create a new playlist key command doesn't work for video. reichman Post - Surround - Video 0 05-14-2011 06:12 PM
Just installed 6.7 and now Command 8 doesn't work? cc1 Pro Tools TDM Systems (Mac) 4 11-01-2004 03:10 PM
