Old 09-23-1998, 02:40 PM
DigiTechSupt's Avatar
Default -34 Media Proxy Time out error message
There have been a couple of reports of this error message and we have several things to look for as possible causes of this message.
The Media Proxy error has to do with the system requesting media it is not receiving fast enough.
- Update to the latest version of AV (as of 9/23/98 that is version 4.1v6)
- If there is sufficient space on the drive, then this could indicate that the Disk Cache (Memory Control panel) is set incorrectly. AV requires this to be set at 96k.
The customer that reported this problem had their Disk Cache set to 512k. Changing this back to 96k (and restarting the Mac) fixed the problem.
- One workaround is to repartition the media drives with the Avid Drive Utility, making sure to change the partition sizes slightly. Older drives that have not been updated, or repartitioned lately may be causing this problem.
- Removing an alias for the Avid Project folder from the Apple menu items cleared this up.
- turning off the "Remember recently used items" option in the Apple Menu Options control panel.
- Check SCSI connections
- Verify Drive configs (wide first in chain, proper termination, etc.)
- Remove unnecessary System Extensions
- Reseat SCSI cards
- Look at where the error is occurring, on certain media, on certain sections of a sequence, re-digitize "bad" media, try a track bounce if there is a section full of fades, etc.
Avid Audio Tech Support
Support FAQ
HTML code is On
message reads I/O setup has changed since last time session was opened last time peteor96 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-05-2011 09:29 PM
Media not supported by video peripheral error message meursiicc Pro Tools M-Powered (Win) 3 09-07-2009 07:41 PM
Media Station taking a long time... Wasaia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-27-2009 12:22 PM
DD client with ISA proxy babel Aspera DigiDelivery 1 04-06-2008 12:25 AM
Song Stops every time at :57 - 9128 error message dts.music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-13-2007 02:16 PM
