Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 07-03-2020, 02:07 PM
SFXgeek SFXgeek is offline
Default Is there a shortcut for this?
I want to add the automation dots (sorry not sure what they are called, keyframes?) to the exact start and end of my selected region using a key command. Is there a key command for this? Please see diagram below.
Old 07-03-2020, 02:09 PM
henningaround henningaround is offline
Default Re: Is there a shortcut for this?
Select the clip and hit CMD+/(keypad)
Old 07-03-2020, 02:29 PM
I tried your suggestion and it won't work for me (and yes tried keypad) is there a specific mode I need to be in for this to work? I tried with volume automation visible also tried with pan automation visible. I'm on mac running PT 2020.
Old 07-03-2020, 02:51 PM
priorytools priorytools is offline
In auto view I double click the region to select, then , c (cmd c) followed by v (cmd v).
This places break piont on region boundaries.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 07-03-2020, 03:09 PM
I must have a preference set wrong, that doesn't work for me either, as far as I know that would only copy and paste any automation that was already there on that selected cue?
Old 07-03-2020, 03:16 PM
With the grabber tool, a simple mouse click on the line will add a break point. Maybe the problem is on the screen and we can't tell from the screen shot. Is it showing volume or is it showing Clip Gain? Volume would be the desired view(or whatever thing you wish to edit such as Pan, some plugin parameter, etc)
Old 07-03-2020, 03:35 PM
Yes it does, but puts a break point on the region bounderies.
Try dragging the select tool from before region start over to after the region end. Now copy & paste.
Do you see break points ?
Old 07-03-2020, 04:37 PM
Ahhh!! I got it to work thanks to your suggestion.
Simply selecting the cue and command c + Command v wasn't doing anything but as soon as I manually added a random "break point" or "keyframe" inside the cue and then Command C + Command V it put "break points" "keyframes" at both ends and kept my manually added break point which is fine by me. Thank you so much!! This has been driving me crazy trying find a quick but accurate way of doing this.
Old 07-04-2020, 04:12 AM
That’s good to hear… But with the select tool if for example you select a section of volume automation on an auxiliary track and command c then command V you will then get two breakpoints.
So if you have some manually written automation and you want to boost the whole lotor lower the whole lot the above method works.
How do I get rid of the Y shortcut? lode Pro Tools TDM Systems (Mac) 14 02-13-2016 10:41 AM
Help W/shortcut spidey01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-21-2009 11:14 AM
Help me with a shortcut ledogboy Pro Tools TDM Systems (Mac) 2 10-01-2009 05:02 PM
Shortcut Key 4 pseradarian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-04-2009 05:13 PM
Shortcut! Bookerv12 Pro Tools TDM Systems (Mac) 0 07-28-2004 07:08 AM
