Will my Mac PT keyboard work under Win7?
It is a USB keyboard so it should, right? Or are there different keys?
Re: Will my Mac PT keyboard work under Win7?
They work fine. The Apple (command) key becomes the "Windows" key. Control is Control and Option is Alt.
There are some slight differences in the key commands then. For instances save is Control-S (standard PC) not Windows-S which would look like it should be since substituting Windows key for the Command key. It can get a little confusing - especially if you are going back and forwarded to different mac/pc systems. I really like the older generation Mac keyboards and think the little brain hassle is well worth it. Once you've used it for a while it will be fine. cya Ghengis
Intel I7-930 Asus P6T-Deluxe V2 6gig Triple Channel 1600mhz HD2 PCI, 96 I/O, Command-8 Win7x64 |
Hi, I got my system up and running and Im installing my plugs now. Yes the keyboard seems to work but as you said many of the shortcuts need to be re-learned thats for sure. I was wondering another thing, is it possible to get apple mouse 360degree scrolling happening? Right now only vertical scroll works, not the horizontal. Thanks again!
Pro Tools on Win7 and Mac Keyboard???? | audiophyle | Windows | 4 | 03-02-2012 06:30 AM |
Win7 64 Bit: Which Plugins Don't work | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-09-2010 10:05 AM |
Win7 x64 MBox 2 - I got it to work; Once upon a time... | korthis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-12-2010 01:58 PM |
anyone on 8.03 win7 get fairchild 660 & 670 to work? | Filmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-31-2010 02:56 PM |
Win7 did definitely not work for me | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 34 | 10-28-2009 10:25 PM |
