Old 01-20-2004, 05:41 AM
lightning ad lightning ad is offline
Default PT compatible video card recommendations please.
we are compiling a kit list for our new HD system, and wondered if anyone is using a different video system to the Avid XL option, which seems rather costly, and a bit of overkill for our needs.
The system will be used mainly for foley recording, and so will need to output a Pal signal to two screens - one in the booth and one for the control room.
Or would i be okay running just a quicktime movie and duplicating the control room monitor on another screen in the booth? (i use this method at the moment on my digital Performer setup and it seems to work although the QT movie size is not huge!)
i'd appreciate your thoughts, as we don't have a bottomless money pit!
adam taylor
video editor/dubbing editor/sound design/motion graphics/compositor
United Kingdom
Old 01-20-2004, 06:11 AM
feliponk's Avatar
feliponk feliponk is offline
Default Re: PT compatible video card recommendations please.
Nvidia FX 5400 or Quaddro
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 01-20-2004, 01:10 PM
Noiz2 Noiz2 is offline
Igniter. You could split the video feed or use a video distribution amp to split the signal to two monitors. We just Y it and it seems to look fine but the amp is the proper way to do it.
Igniter ~$1000 Horita DA ~$230
www.scottkouesound.com
SK
Old 01-23-2004, 08:54 AM
trakbytes trakbytes is offline
Radeon 9800. Send one feed to the computer monitor, send the S-VHS output to your control room TV and run a composite split from that to your studio monitor. Works well, scrubs in sync. Can't capture, though. Igniter card mentioned above is probably also a good choice, but puts the video back on the PCI bus. The Radeon replaces the internal graphics card, and doesn't take up a PCI slot.
rcm
Save early and often! (or once a day whether you need to or not...)
Old 01-24-2004, 07:46 AM
TheVectorWarrior TheVectorWarrior is offline
That Radeon 9800 sounds nice, but is that the mac version? I had a look on the apple and ATI website at the 9800 and there is no mention of a SVHS output on it.
Old 01-24-2004, 03:27 PM
well you've all convinced me that the avid option is not an option for us at all !!
I'll stick with what I have on my motu set-up - which is a Geforce 4ti 128mb - its comparable with the cards mentioned, and as it ain't broke.....
thanks
adam taylor
United Kingdom
Old 01-26-2004, 06:50 AM
Here's the link to the Radeon 9800 spec sheet. Radeon 9800
THe SVHS port is listed in the specifications page for the Mac. I have been using the 8500 (now discontinued). However, please note the 9800 only works in OSX, so if you are still using OS9.2 it won't work.
rcm
Old 01-27-2004, 10:49 AM
Thanks for that, i didn't look at the 'pro' model. It doesn't have a ADC interface but has a VGA instead which is a shame and it is only AGP4X rather than 8X. Aside from that it looks great, i might get one. Thanks for the heads up.
Old 02-01-2004, 05:51 PM
emf1138 emf1138 is offline
What's wrong with the DC30+??? You can find 'em here in the DUC or on eBay for under $100 and it's fully compatible (though not DIGI supported) with PT 6.x.x (PAL & NTSC)! We use 'em in all our edit rooms and mix stages. The OS X drivers are FREE!
Eric Freeman, CAS
Sound Supervisor/Re-Recording Mixer
Disney TV Animation
IMDB
LinkedIn
Old 02-04-2004, 11:30 AM
Unforunately they dont work with the G5 due to the infamous 3.3 volt requirement
HTML code is On
Video Card Recommendations txshonk Windows 2 02-02-2013 11:00 AM
Video card recommendations for new PTHD AND video editor build... songwritersoul Pro Tools TDM Systems (Win) 0 03-24-2012 07:31 AM
Third monitor video card recommendations? xxicjoy Pro Tools TDM Systems (Mac) 1 02-04-2010 11:58 AM
Is this video card compatible? oregafro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-22-2009 09:03 PM
Video Capture Card Recommendations? duderonomi Post - Surround - Video 4 10-16-2003 06:16 AM
