Old 01-17-2020, 03:00 AM
Peterjk's Avatar
Peterjk Peterjk is offline
Default ADAT io without Digital IO?
I was hoping someone could test/verify this:
The ADAT IO on an Avid HD IO, work regardless of the IO cards in the HD IO itself - right? (Lot's of IO in that sentence).
Peter
Old 01-17-2020, 03:12 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: ADAT io without Digital IO?
What is it you are asking? In case you are thinking empty chassis would be functional, it is not. There is a minimum number of cards that need to be present until HD interface works. I am not completely sure if it is two, but at least the analog interfaces are functional if one card fails.
Janne
Old 01-17-2020, 12:03 PM
BScout BScout is offline
Peter
Yes.
(They are referred to as the Enclosure I/O or Enc ADAT)
The Enc outputs can all mirror the same signal.
The inputs have to be selected specifically in Hardware setup.
ADAT to PTMixPlus via ADAT bridge...digital pops? Phattlippz Digidesign Hardware & Software 2 05-28-2006 05:13 PM
Connecting Adat via digital Rudyman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-23-2005 02:34 PM
Tascam Digital / ADAT Digital Conversion Vyper_Mk_II 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-23-2002 02:54 AM
digital I/O :AES or Adat ? phil kerg Pro Tools TDM Systems (Mac) 4 04-16-2002 08:14 AM
ADAT digital....?? Slim Shady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-04-2001 05:49 PM
