Old 12-21-2007, 04:46 PM
ebonyles ebonyles is offline
Default White Noise when arming audio in
I'm using an mbox2- I've never had this problem before but I just tried arming an input to record some guitar tracks and the track immediatly clipped with steady white noise. Nothing is clipping going in (Pod XT Live). I tried unplugging all inputs in to the mbox and it still did it. I does it on both input 1 and 2, and though it never has before, it's doing it on all my sessions now. I haven't changed anything internally that should cause this...
Please help!!!
2.66Ghz Mac Pro Duo Core 3GB Ram
OSX 10.5.6 MBox2 External 250GB HD
PT LE 8.0cs2
Battery3, Klassic Keys, Addictive Drums, RennMaxx, Production Toolkit, Vienna Special Edition
Old 12-21-2007, 07:26 PM
sky88dd sky88dd is offline
Default Re: White Noise when arming audio in
Did you by any chance put your Mac to sleep while you're away?
PPC G5 Dual 2.0, 8.5G Ram
PT 8 cs2 OSX 10.5.8
MBP Core 2 Duo 2.16, 2G Ram
PT 8 cs2 OSX 10.5.8
Mbox 2 Pro, Mini, Micro
Old 12-22-2007, 07:57 AM
Yeah but it's never happened before...
PT LE 8.0cs2
Old 12-22-2007, 02:42 PM
Jussi Jussi is offline
It's due to putting the computer to sleep, I think, PT doesn't like it. Sometimes white noise occurs, sometimes not.
I had the same problem. You might avoid it completely by not using "sleep". However, if you carry on using it, solution in any case: http://web.mac.com/jcdeshaies/Delete...Bienvenue.html
> then empty trash, and restart.
mp (8x2,8ghz 8gb) mbp (c2d 2,53ghz 4gb) osx10.6.3 pt8.0.3 mptk2 mbox2
www.myspace.com/pukspace
eSoundz name: jus11
Old 04-26-2020, 04:04 PM
DinoVert DinoVert is offline
I have the same issue but that link is no longer valid, could you explain this solution?
LOUD Audio white noise? jflowers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-31-2012 11:01 AM
White noise on new audio tracks jglunt2112 Pro Tools M-Powered (Win) 0 08-13-2012 05:38 PM
Audio Drop outs and white noise on audio recordings. Ronny Milianowicz Pro Tools TDM Systems (Win) 12 06-11-2008 01:48 PM
White noise replaced audio? BeachDog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-12-2005 09:00 AM
import audio and only get white noise Kris75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-20-2002 04:21 PM
