Old 07-31-2018, 10:24 AM
bom619 bom619 is offline
Default 2018.7 update fixes the DSP spikes (mac)!
My system hasn't performed this well in at least 8 months. I can again record into complicated sessions at 24/88.2 with a buffer of 64 samples.
EDIT: Well that was nice while it lasted. 8 hours later (of course when musicians show up) the CPU started to go berserk with spikes and errors. Had to turn hyperthreading off again so I could record. Soooooo unhappy.
EDIT AGAIN: Can someone (mod) delete this thread? The title is no longer accurate and people will find the entire premise misleading.
OSX 10.13.6
Mac Pro 5,1 (flashed efi) 12 X 3.46 Ghz 32gb Ram
Orion 32 (usb)
Old 07-31-2018, 10:28 AM
adam_w1 adam_w1 is offline
Default Re: 2018.7 update fixes the DSP spikes (mac)!
such good news, thank god!
Old 07-31-2018, 11:28 AM
innesireinar innesireinar is offline
The 2018.7 with the HDX is unusable, maybe worse than the 2014.4
I've just created a session with only 40 stereo audio files (80 voices) (from CDs) with no plugins and with no additional plugins installed since I've just reinstalled Pro Tools from scratch. I'm not able to play the session at 64 samples and at 128 the CPU jump to the middle of the meter.
Whole different story by playing the session with the internal mac audio (Build-in line out) where all seems to work fine with the CPU around 5%. The weird thing is that by closing the edit window the CPU goes down dramatically (with the HDX). Maybe a graphic issue? But why this doesn't happen when using the internal audio mac?
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 07-31-2018, 12:18 PM
toolz toolz is offline
+1 my situation is identical with HDX, fine with built in sound.
Just to note, that I did a support ticket 3 months ago, and Avid recreated the issue on their identical setup.. but no bug fix..
[B][SIZE="1"]System:
PT 12.8.1 HD-Native PCIe, 48 I/O 16x16, 2012 Mac Pro 12 core 3.46Ghz 64gig RAM, UAD Quad FW, Apple 30” Cinema
Old 07-31-2018, 02:35 PM
Peter Baird's Avatar
Peter Baird Peter Baird is offline
-9093 after working for 10 minutes. HDN, 128 samples. Small session. Restart PT, immediate -9093 on playback.
2018.7 HD Driver installed.
Peter
Gypsy: PT Ultimate 2019.5, 12-core Mac Pro 3.46Ghz 64GB OS 10.14.5, HD Native, HD OMNI, 2 Artist Mix, EUCON 18.3, Presonus 32R, Studio One 4.5.1, Quad Eight preamps, Neve 3201 EQs, 2 LA-4s, Malone Design Works desk
Laptop: 10.13.6 MacBook Pro 2.8 Core i7, 16G, PT 19.5 Live 9
www.remotewest.com
@RemoteWest
Old 07-31-2018, 02:59 PM
wafare wafare is offline
Curious, did you guys install the 2018.7 HD driver? I'm working fine here.
2013 2.7 Ghz 12-Core Mac Pro
64 GB Ram
1 TB SSD
OS X 10.14.6
Lynx Hilo TB D/A
Prism Lyra A/D
Apogee Symphony MKII 2X6 SE
Pro Tools Ultimate 2019.12
MASELEC MTC-1x
MASELEC MLA-2
MASELEC MEA-2
MASELEC MPL-2
MASELEC MLA-4
MANLEY (Mastering) SLAM!
MANLEY MASSIVE PASSIVE (Mastering)
X2 Rupert Neve 5059
WAVES L2 Ultra Maximizer
Artist Control
X2 Artist Mix
Old 07-31-2018, 03:11 PM
Obviously. But I see that you run the Thrashcan that has a more powerful video card and you don't use the HDX. Just because from my test I'm sure that this issue is related to graphic tasks given that with the PT windows closed the session that I'm using for the test run flawless at 64 samples. And this happens only when using the HDX
Old 07-31-2018, 03:25 PM
Yes, I do run a trashcan but I have more than one. I do have a chassis with (2) HDX cards as well and as stated I'm running fine.
64 GB Ram
1 TB SSD
OS X 10.14.6
Lynx Hilo TB D/A
Prism Lyra A/D
MASELEC MTC-1x
MASELEC MLA-2
MASELEC MEA-2
MASELEC MPL-2
MASELEC MLA-4
X2 Rupert Neve 5059
Artist Control
X2 Artist Mix
Old 07-31-2018, 03:38 PM
Could you tell which settings you are using on HDX based sys?
Type of the session (I'm having issues especially on sessions with lots of audio files, more than when using VI), SR/bit depth, buffer setting,
I need to investigate why this issue happens only when using the HDX and the 2018 family, on Yosemite with PT11 the HDX works very well
Old 07-31-2018, 04:27 PM
As suggested, just saying.. I got this and it's working great! helps no one!
We have serious issues, on supported computers and all Avid hardware.
PT 2018.1.0 CPU spikes energee macOS 7 04-14-2018 11:13 AM
Pro Tools 2018.1 CPU Spikes anotherone Pro Tools 2018 11 04-10-2018 09:09 AM
10.0.1 Update fixes gravol macOS 3 01-29-2012 07:36 PM
Update/Fixes to PT Free coming soon Kenn LeGault Digidesign Hardware & Software 8 11-25-2000 03:47 PM
