11 rac power issue
11r sporadic power shutdown then resets back by its itself . no error message changed power cord !
Re: 11 rac power issue
Do you have anything stacked on top of the 11R? It could be overheating and shutting down. Do you have it plugged into any kind of power conditioner? That would be a good thing as most municipal AC power has all kinds of crud on it, not to mention what's also on the same side of the line in one's house. |
It could be the power supply inside but I'd take it out of that rack and let the thing breathe. Heat is the enemy of electronics. |
Iam testing that now. thanks for the help.
Did a 5hr session out of the rack, no issues. fired it up next day, shutdown in 15min twice. felt no heat on unit !
Very strange. One last thing to try before trying to get it fixed by Avid - can you leave the unit powered on and connected to nothing other than an AC outlet? Like overnight maybe? I know I'm grasping at straws but wondering if something's coming in that tells it to shut down. When you run it is it also plugged into a computer via the USB port?
I will try your suggestions. All other tests were with USB plugged in computer. Thanks again
Unplugged USB, midi, main outs, Played thru gtr input phones out for about an hour shutdown and started again. It takes about 15 seconds for the reset
Well you've tried everything I can think of - guess it's time to try and get it fixed if you can find someone to do so.
C|24 power issue | edmatthews82 | ICON & C|24 | 1 | 03-31-2014 12:43 PM |
Digi 002 Power Harness Issue or Firewire Chip Issue? | Nish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 35 | 05-07-2010 01:25 PM |
002 power failure issue? | madoneman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-13-2008 07:57 PM |
002 Power Issue. | therightclique | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-27-2005 10:21 PM |
002 rack power harness power suplly issue | rockstah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-06-2004 11:04 PM |
