Most Stable Windows Version for PLAY, Vienna etc?
I don't need a whole raft of plug-ins. But I do need EastWest Platinum Orchestra (and a few others from EW), Vienna Ensemble Pro with Special Edition, Auto-Tune 8.1, Ivory pianos, and Pitch n Time to work well. Everything else is negotiable.
Currently: Windows 10 Pro PT 12. 4 Scarlett 18i20 Mytek Stereo ADC for clocking It's just too buggy for me to work with any kind of momentum. I keep trying to make it work, but it's never quite there. There are many and varied MIDI related issues; PLAY crashes if there are too many instruments or a couple instances; auto-tune is even a little dodgy. Scarlett seems to part of the problem at times. I've jumped through the hoops I know to jump through (nuked prefs, Avid system optimizations, Windows not using the Scarlett etc) and although it may work well for a couple days, it always deteriorates. Is anybody working on Windows 10 with PLAY and Vienna successfully? Maybe going back to 11.3.2 is the best plan, as some have suggested?
"Modern manufactured music is like art they sell at a furniture store." http://www.weddingmusicproject.com/ http://www.weddingmusicproject.com/w...music-samples/ http://stevemillikan.com/ |
Re: Most Stable Windows Version for PLAY, Vienna etc?
Same config, pretty much.
Windows 10 64bit PT 12.7 Scarlett 18i20 (tested every xxxkHz/buffer sizes) Tried to use PLAY from EastWest (ComposerCloud). Latest version of ALL drivers and softwares (Windows, Focusrite, PT 12.7, PLAY 5.0.1 etc...). Everything fully updated. PT hangs every 5 mn with a msg: Assertion in "..\ ..\ Sys\ Win32\ Sys_FileLocWin32.cpp", line 548. For me, the number of instruments is irrelevant, it just happens even more with more instruments... I'm lost!!! Any ideas welcome. (also sent to EastWest support... awaiting a solution) Current best idea: I followed the instruction from Focusrite web saying to install an "older" USB driver for the Scarlett, to make PT12.7 more stable... maybe it's related??? dunno... |
Theres alot of factors. usually its a good idea to reinstall the avid drivers, and also update any of your windows drivers. Now, i have seen other instances where the computers ram was unstable, failing, or just not fast enough. Some computers have a bottleneck and have problems with sound computation. one of the most stable versions of windows ive worked on has been windows 7 professional. If you have windows 10 id suggest the enterprise/educational version. and finding the most stable version of the drivers for you hardware regardless of the age.
Update eLicenser - Version 6.7.0.5140 – for Vienna Ensemble Pro 5 | unkJE | Virtual Instruments | 0 | 02-11-2014 02:14 PM |
PLAY and PT 11- anyone stable? | notedmusic | Windows | 1 | 01-15-2014 08:27 AM |
Most stable PT 9 and OSX 10.6 version? | allen_gibberish | macOS | 6 | 11-06-2011 04:07 PM |
Most stable OS version | OddsAre | macOS | 3 | 02-01-2011 11:44 AM |
Is the PT .5.0 stable version? | JACEK GAWLOWSKI | Pro Tools TDM Systems (Mac) | 11 | 01-19-2000 12:55 AM |
