Headphones I/O configuration
Pro Tools 9 HD Native
Pro Tools HD 192 16x16 analog interface Mac Pro tower, 12 core 32 GB RAM OSX: 10.7 C/24 control surface Even though I've been a PT driver since before it was called Pro Tools, I can't for the life of me get my I/O configurations to simply feed the main outs (1 & 2 in a PT session: 1 & 3 from the HD interface for the L&R surround sound feed to the C/24) to a another stereo output to feed the input of my headphone matrix. To put it more simply, I just want to split the signal the is going to my stereo monitors and simultaneously send it to my headphone matrix. PLEASE don't describe how to create sends for each track to AUX or Master faders: 1) I know how to do this, and 2) I don't want to create dozens of unnecessary sends that consume processing power and will be turned off by low latency monitoring. I just want to send my main stereo monitor feed to Analog 9 & 10, while maintaining the feed to the monitors. Thanks! |
Re: Headphones I/O configuration
Will holding down the Command key and clicking on the Master output (1/2) in your session reveal a menu that will allow you to do what you want?
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
Thanks for the suggestion, Greg. I'll try it when I get back to the studio in the morning.
BTW...I'm also from the Twin Cities, though I've been on the Gulf Coast for many years. Raise a pint at Kieran's Pub fer me, Bucko! |
Just found my answer (pasted below)...aint manuals great.
I was going about it backassed by creating a new output path for the heaadphone matrix and overlapping the Main out and Headphone out. --------------------------------------------------- To route a Pro Tools output channel pair to multiple audio interface output ports: 1 Choose Setup > I/O. 2 Click the Output tab. 3 Click the Output selector for an interface channel pair, just below an audio interface icon. 4 From the pop-up menu, select a physical port pair (such as Analog 12) to route to the corresponding Pro Tools channel pair (such as A 12) in the Path Name column on the left. 5 Start-click (Windows) or Control-click (Mac) the same Output selector and select an additional output pair from the same pop-up menu. The output name updates with a plus sign (+) before it to indicate that multiple output ports are selected. In the pop-up menu, each physical port pair assigned to that Pro Tools output pair is indicated by a check mark. 6 Repeat the above steps to select additional output destinations. 7 Click OK to save changes and close the I/O Setup. |
I was just trying to figure out the same thing. Thanks for posting:)
You do know that the C24 uses outputs 1&3 for left and right(2 is dedicated to the center of 5.1).
I tried using the protocol outlined by seafra. This would not work for me in Setup/IO, but I can make individual track output adjustments by track. Is there some setting I'm missing. I'm using PT 12.7.1. Thanks!
Help with Hd configuration | MisterQtastic | Pro Tools TDM Systems (Mac) | 1 | 06-12-2011 04:59 AM |
Best Mac Pro Configuration | Nick Melander | macOS | 9 | 04-05-2011 06:58 PM |
PC Configuration | Leeroy | Pro Tools M-Powered (Win) | 2 | 10-20-2010 12:51 AM |
PC CONFIGURATION | JOTASAN75 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-20-2001 08:57 PM |
The best PC configuration | Ssaidvox1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-15-2001 09:51 PM |
