Midi cc learn plugins 12 HD
Hi
How do you do midi cc learn on Protools HD. It used to be simply right click on parameter in plugin then select midi learn then send midi to assign. or Ctrl click now neither work. Has it changed
WIN10 12.6 HD Native, Omni, BlackLion XB192 |
Re: Midi cc learn plugins 12 HD
Is there a way to also get your controller to focus on what ever appplet is open or brought forward so that controller can be used to map several instances of a plugin without moving all mapped plugins but rather just the instance that is in focus or brought forward.
Kind regards
Nothings changed; it's up to each plugin developer on whether you can do MIDI learn and how that happens. I've yet to see any kind of MIDI learn for any Waves plugins. I just looked at the 560 manual and there is no MIDI learn. This is not to say you can't automate the controls but that has to be done through automation lanes in PT using PT's automation system. For that - RTFM.
PT9 crashes after mapping plugins in learn mode | luiger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-18-2011 09:40 PM |
To Digi Tech Support - on the importance of freely assignable MIDI Learn of plugins | AlessandroRatoci | Pro Tools 9 | 11 | 05-25-2011 02:27 PM |
Midi Learn on 3rd Party Plugins | scenicrecords | Tips & Tricks | 4 | 10-26-2010 06:54 PM |
MIDI Learn with Moogerfooger Plugins | node100 | Tips & Tricks | 4 | 05-01-2010 01:42 PM |
Learn this lesson about Multimono Plugins | deanguidry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-28-2008 01:19 PM |
