Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 03-28-2010, 12:40 PM
rpantzer rpantzer is offline
Default Sending one delivery to several e-mail adresses- bug?
I tried sending a small delivery to 8 different e-mail adresses and the mail witht he download link only came to half of them.
Is this a known bug?
How do I get around this problem? Do we need to send one delivery to each mail adress?
Digidelivery says it sucessfully sent the delivery and when I log in to the server using the admin account the deliverys says pending on all e-mails.
Does anybody know what to do to avoid this problem in the future?
Thanks
Old 03-28-2010, 01:14 PM
Default Re: Sending one delivery to several e-mail adresses- bug?
Ask your recipients to check their spam-folders. If an address is wrong you would get the "couldn´t deliver email" notification back so the emails must have reached their accouts.
Old 03-28-2010, 02:02 PM
I have looked in the spam filter and there is nothing there.
I have also double checked the adresses and they are correct.
Any other theories what went wrong?
Old 03-28-2010, 02:43 PM
Weird. I haven´t seen this before. Are you using the built-in mail-server of the DD-LT or an external one?
Old 03-28-2010, 07:54 PM
Top Jimmy's Avatar
Some ISPs will filter mail without it even getting into a spam folder if the "A" record, host name, IP address, and/or reverse lookup don't agree. See the link, it might help.
http://duc.digidesign.com/showthread.php?t=209317
_
James Cadwallader
Old 03-28-2010, 11:50 PM
When they didn't get the email I sent one delivery to each e-mail adress and then it worked. So the spam doesn't seem to be the problem.
Frank Kruse:
I'm not sure I understand you, which one is the build in DD server? We have the GT server.
I am taking e-mail adresses from my adress book if that answers your question?
Old 03-29-2010, 01:54 AM
Originally Posted by rpantzer View Post
Frank Kruse:
What have you set the GT to under "Email settings/Mail Server settings/Mail server address"?
Old 03-29-2010, 02:12 AM
It is set to our e-mail server.
Do you think I should I change it to something else?
I have no problem sending deliverys to single e-mail adresses.
Thanks!
Old 03-29-2010, 03:46 AM
Thanks!
Try setting it to "default" (127.0.0.1) and see what happens. It seems like your mail-server is the cause of the problem.
Mine is set to default and I´ve never seen this.
It could also be the reverse-lookup (hostname doesn´t resolve to the IP of the server) issue and the receiving server is blocking the email as spam before it even reaches the inbox. But normally such mails would bounce back to you.
frank.
Old 03-29-2010, 09:07 AM
I've tried setting the e-mail server to default as you said and re-sent a delivery to several e-mail adresses. But I still have the same problem. Some adresses didn't get the e-mail.
Any other ideas?
It's a bit frustrating
Delivery e-mail delays Rick Sanchez Aspera DigiDelivery 11 12-08-2010 10:17 PM
Are digi email adresses valid??? tamasdragon General Discussion 2 01-17-2010 03:52 AM
Sending an E-mail skwalker68 General Discussion 4 02-05-2009 04:30 PM
M & E Delivery SurroundNewbie Post - Surround - Video 1 04-17-2004 03:16 PM
What is the best db for delivery? RobMacki Post - Surround - Video 10 07-24-2002 03:36 AM
