Old 10-12-2019, 03:40 PM
deibisantafe deibisantafe is offline
Default The shortcut "ALT K" does not work when the system is in play
Goodnight everyone.
I have relatively recently a Protools HD 10 (official of course) running on an HP XW8400 PC, with two PCI-X cards, one HD Core and one HD Accel, as well as two 192 i / o, one analog and one digital .
Everything works without problems except one issue: track monitoring.
I have been with a Digi 003 for years, and the ALT K shortcut has always worked to alternate between incoming signal and signal recorded on the track, whether it is stop or play. All right. Well, for some reason I don't know about the system I have now. ALT K doesn't work once the system is in play. The green light of the "I" icon turns on and off if I press ALT K, but the monitoring status does not change, the one that was selected is kept before pressing play.
Any ideas? I'm lost
A million thanks
Old 10-12-2019, 05:18 PM
BScout BScout is offline
Default Re: The shortcut "ALT K" does not work when the system is in play
I think you are using a deprecated shortcut. It's Shift+I. Works fine here but I'm not on 10HD. If this doesn't work, you might want to post in one of the Legacy Products forums (TDM or Pro Tools 10)
Old 10-12-2019, 06:05 PM
jeam25's Avatar
jeam25 jeam25 is online now
Hi Shift+I activates input monitoring while playback and Atl+K activates input monitoring while recording. Testing here right now and still working as is.
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
"Play MIDI Notes When Editing" Shortcut? Ru_C macOS 1 12-07-2013 08:49 AM
Mac Keyboard shortcut for "Hide Pro Tools HD" does not work in 11 The Recordist Pro Tools 11 6 11-24-2013 02:35 PM
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface eanderso22304 macOS 3 11-23-2011 06:45 AM
Keyboard shortcut to toggle "Play MIDI Notes When Editing" Soul Finger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-17-2010 06:29 PM
