Flashing Track Record Button in Mix Window??
For the first time when 'arming' a track for recording (in the last few sessions I've created), the track record button flashes. Maybe my mind is going (well, or despite that fact) but I don't recall that ever happening...I think normal behavior is a flashing led in the edit window (and of course the transport) but I have sessions where the led is static in record mode...and others that it's not, as far as I can tell all the settings and preferences are the same.
What am I missing?? Other than a few brain cells... S. |
Re: Flashing Track Record Button in Mix Window??
The plot thickens....Digi Support says that the record enable LED is supposed to flash in the Mix window...Is it possible I haven't noticed that (though I am coming from an older version of Pro Tools and new to 6.4) That means if a track is record enabled and the record button on the transport is pressed (standing by), I have four blinking LED's.....I'm going to have a seizure....Though it does put me in the holiday spirit....
So is this normal...blinking when engaged / solid when you start recording in both mix and edit windows? Steve |
This was changed in 6.4 I believe... what you're seeing is now normal.
Rail
Record 1 audio track, then go to record a second, the timer button flashes... help | tdubthatsme | General Discussion | 5 | 02-27-2011 04:39 PM |
track target button gone in PT8 mix window | paulreed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-17-2009 09:59 AM |
Play and Stop Buttons both flashing - track window froze | Matt Darcy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-08-2008 01:13 PM |
Green Record Button In Tranport Window | Wheelieboy426 | Pro Tools TDM Systems (Mac) | 2 | 10-18-2002 10:42 PM |
Transport window record button greenage... | cubasteve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-04-2001 12:41 AM |
