Re: ProTools M-pwered help!!!
Yes I can see the click track and the track that I'm trying to record on,if that is what you mean.
Sorry, what I meant to ask. Is there are region created everytime you try to record a take on a track. The region list is down the right hand side of the screen. Everytime you record a "take" it should add to the region list. Is that happening and if so, are empty regions being created, i.e. regions with no wave representation in them.
Sorry I read my previous note... I meant the right hand side of the screen.
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Are you trying to record audio to an instrument track ?
#16
#17
I was assuming an audio track because audio could be dragged and dropped to it and it worked... somewhere back up the thread....
#18
Sorry about the audio track thing...I just dragged them into the window to see if it even performed doing anything at all.Someone asked me to push either F12 or the Apple+spacebar,this got it to do the psuedo record thing,as usual it goes but doesn't record anything!!!Got all the red lights going but it doesn't record.....I got the screenshot done and here is the place to get it...hope this helps you all out I'm really frustrated now....
http://bp1.blogger.com/_qHQg7DuLwH8/...600-h/PTMP.jpg |
#19
Based on your screenshot (very good suggestion by the way) It looks like you are trying to record audio to an instrument track which is not possible. (Instrument tracks are reserved for passing virtual instruments' audio) I see earlier in the string you even mentioned "instrument track".
You can create an AUDIO track (Track menu-> NEW-> Audio track) and follow the previous suggestions (record enable a track, verify the inputs and outputs etc..) Please re-visit your manual (under the HELP menu) for detailed recording instructions. That should get you started... |
#20
Thanks will try that after work!!! I just assumed that recording an instrument would require and instrument setting,my bad maybe I didn't read everything that closely!!! Now I'm anxious to try this,wish me luck!!!!
changing from protools 8 audio only to protools 8 with video support | djkaz | macOS | 5 | 09-04-2013 04:00 PM |
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? | jgbsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-03-2011 01:08 AM |
Sending protools projects to other protools users online | kdtufan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2008 07:18 PM |
m-pwered protools and midi setup | godzflava71 | Pro Tools M-Powered (Mac) | 2 | 09-14-2005 10:28 AM |
setting record levels into ProTools with the intent of mixing in ProTools | Felix | Tips & Tricks | 507 | 02-05-2002 10:17 PM |
