Old 01-10-2000, 08:50 AM
maxtraxstu maxtraxstu is offline
Default SSD..updated firmware, now light just flash, doesn\'t work!! HELP!!
I have an older SSD, I bought used, I just started using it to lock my 2" up to PT. I downloaded the SSD setup 1.31, and updated the firmware. I powered up holding down a button, to put it in udate mode, I updated the firmware and it said it was successful. Great!! Now it seems to be stuck in update mode and does not work, no matter what I do, nothing communicates with it, nor do any of the buttons work. Could it be too old for the 1.31 update, and if so, are there older updates that could be emailed to me.
I need this to lock up by this weekend!! Please help.
Thanks a lot,
Paul
Old 01-12-2000, 01:04 PM
Techsupt2 Techsupt2 is offline
Default Re: SSD..updated firmware, now light just flash, doesn\'t work!! HELP!!
maxtraxstu
There might of been an issue from the download from the web?
Have you tried another SSD 1.3.1 update again from our web site, tried downloading the SSD setup from another internet service, powered cycled the SSD/System, made sure no signal was being sent to the SSD when updating.
I've emailed you SSD setup 1.2 and 1.3 to see if that helps in any way.
Emails to Digidesign get responded in three business days or less though we are extremely busy here during the new launch of Pro Tools v5.0 and the Digidesign 001. Thanks for being patient.
Let me know
Brad
Old 01-13-2000, 12:15 AM
doesn't anyone have any info on this major problem I am having with the SSD. I tried emailing Digi, but no response so far..
Please Help
Thanks
Paul
Old 01-16-2000, 07:31 AM
Brad,
I still cannot get the SSD 1.2.1 and 1.3.1 that you sent me to open. I keep getting a -39 type error. I tried them on a couple diff. machines and downloaded them a couple of times. Stuffit doesnt recognize them either. Can you send me them again uncompressed?
It worked perfectly befoe I tried to uplaod the new firmware. I also zapped the P Ram, nothing and tried both serial ports.
Thanks
Paul
Old 01-16-2000, 05:26 PM
AMG AMG is offline
Paul,
There is an issue with running SSD firmware update with OMS active. Try again with version 1.31 but restart your Mac with all the extensions off (hold the shift key down at startup). Run the update and see if your unit comes up ok. I doubt your unit is too old. I have two of the oldest units, plus I have used one of the original prototype units that Digi sent out to beta testers and all are updated to 1.31 of the firmware.
good luck,
alberto garcia
Old 01-16-2000, 10:00 PM
-MaxTraxStudios- -MaxTraxStudios- is offline
Thanks for the tip Alberto, I will try it as soon as I get to the studio tomorrow, I hope it works, I really need to lock up my 2" to fly stuff into PT by next weekend.
Thanks Again
Paul Benedetti
Max Trax Studios http://www.maxtraxstudios.com
[This message has been edited by -MaxTraxStudios- (edited January 16, 2000).]
Paul Benedetti
Max Trax Studios
Old 01-18-2000, 03:52 PM
Yes!!! Turning off the OMS extension worked!! SSD is back in the house, Thanks a lot.
Paul Benedetti
Max Trax Studios
Paul Benedetti
Max Trax Studios
HD Native Firmware Flash TimNielsen macOS 5 01-29-2012 01:59 PM
MIDI I/O Firmware flash? DetroitT MIDI 0 09-26-2011 08:52 AM
RESOLVED: I updated PT LE 8.0.1 to 8.0.5 AFTER the Eleven Firmware-Flash... _mat Eleven Rack 2 03-24-2011 11:53 AM
Updated to Intel/updated plugins don't work Mixtrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-09-2007 07:59 AM
6.0.2. - Firmware needs to be updated? Axehell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-18-2003 08:50 PM
